DHT Library/Sketches and 2 Projects
Hello, I don’t know where I could put this formula in to properly work in this library. Can someone help me? Also, after that is put into that library, how could these sketches be updated to include the dew point reading? I’d really appreciate any help. I have attached the library file. Here is the Fahrenheit dew point formula that I would like to add:
(243.04*(log(h/100)+((17.625t)/(243.04+t)))/(17.625-log(h/100)-((17.625t)/(243.04+t)))*1.8+32)
Here are the 2 sketches I’d like to update:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 7     // what digital pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT22  //DHT 22 (AM2302)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(60000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print(f);
  Serial.print(" \t");
  Serial.print(h);
  Serial.print(hif);
  Serial.println(243.04*(log(h/100)+((17.625*t)/(243.04+t)))/(17.625-log(h/100)-((17.625*t)/(243.04+t)))*1.8+32);
And the second code:
[/code]#include <LowPower.h>
#include <BH1750.h>
#include <SFE_BMP180.h>
#include <DHT.h>
#include <Wire.h>
#include “Sodaq_DS3231.h”
#include <SD.h>
#include <SPI.h>
#define DHTPIN 2
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define ALTITUDE 216.0 // Altitude in Sparta, Greece
char TEMPERATURE = ‘C’ ; //Change it to F to log degrees Fahrenheit
int INTERVAL = 1; //interval of measurements in minutes
DateTime dt(2015, 12, 14, 9, 28, 40, 1); //Date and time
int CS_PIN = 10;
int ledPin = 7;
int POWERPIN = 3;
File file;
DHT dht(DHTPIN,DHTTYPE);
SFE_BMP180 pressureSensor;
BH1750 lightMeter;
int id = 0;
void setup ()
pinMode(POWERPIN, OUTPUT);
digitalWrite(POWERPIN,HIGH);
pinMode(ledPin, OUTPUT);
initializeSD();
//rtc.setDateTime(dt); //Adjust date-time as defined ‘dt’ above
void loop ()
String temperature;
String humidity;
String light;
String pressure;
String entryId;
String dateEntry;
id++;
digitalWrite(ledPin,HIGH);
delay(2000);
initSensors();
delay(10000);
entryId = String(id);
humidity = String(dht.readHumidity());
if(TEMPERATURE ==‘F’)
temperature = String(dht.readTemperature(true));
}else
temperature = String(dht.readTemperature());
pressure = readPressure();
light = readLight();
dateEntry = DateLogEntry();
String entry = entryId+","+dateEntry+","+temperature+","+humidity+","+pressure+","+light;
writeEntryToFile(entry);
delay(2000);
sleepForMinutes(INTERVAL);
void initSensors()
Wire.begin();
rtc.begin();
dht.begin();
pressureSensor.begin();
lightMeter.begin();
void sleepForMinutes(int interval)
int i=0;
int seconds = interval*60;
int iterations = seconds/8;
for (byte i = 0; i <= A5; i++)
pinMode (i, OUTPUT); // changed as per below
digitalWrite (i, LOW); // ditto
digitalWrite(POWERPIN,LOW);
for(i=0;i<iterations;i++)
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
float readPressureFromSensor()
char status;
double T,P,p0,a;
status = pressureSensor.startTemperature();
if (status != 0)
delay(status);
status = pressureSensor.getTemperature(T);
if (status != 0)
status = pressureSensor.startPressure(3);
if (status != 0)
delay(status);
status = pressureSensor.getPressure(P,T);
if (status != 0)
p0 = pressureSensor.sealevel(P,ALTITUDE);
return p0;
String DateLogEntry()
String dateEntry;
String year;
String month;
String day;
String hour;
String minute;
DateTime now = rtc.now();
year = String(now.year());
month = String(now.month());
day = String(now.date());
if(now.hour()<10)
hour = “0”+String(now.hour());
}else
hour = String(now.hour());
if(now.minute()<10)
minute = “0”+String(now.minute());
}else
minute = String(now.minute());
dateEntry = month+"/"+day+"/"+year+" “+hour+”:"+minute;
return dateEntry;
String readLight()
uint16_t lux = lightMeter.readLightLevel();
return String(lux);
String readPressure()
String pressure;
pressure = String(readPressureFromSensor());
return pressure;
void initializeSD()
pinMode(10, OUTPUT); // change this to 53 on a mega // don’t follow this!!
digitalWrite(10, HIGH); // Add this line
if (SD.begin(CS_PIN))
digitalWrite(ledPin,LOW);
} else
return;
int openFileToWrite(char filename)
file = SD.open(filename, FILE_WRITE);
if (file)
delay(200);
delay(200);
delay(200);
return 1;
} else
return 0;
int writeToFile(String text)
if (file)
file.println(text);
return 1;
} else
return 0;
void closeFile()
if (file)
file.close();
void writeEntryToFile(String entry)
openFileToWrite(“log.txt”);
writeToFile(entry);
closeFile();
}[/code]
DHT.txt (8.35 KB)
You need to research how to convert a double to a string so that you can write it to your text file.
... and it's a double post, which is frowned on... https://forum.arduino.cc/index.php?topic=385172.0
I would have deleted this thread if I could have. I didn't realize I couldn't until earlier. Sorry aarg and thanks for the advice from the other post.
