// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
Serial.println("DHTxx test!");
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C");
Hmm! I can't find a lot out about that. I can guess how the pins are connected but that's not always a good idea. Do you have a multimeter to confirm how they are connected?
However, I would suspect that the resistor on the board means that you don't need to add one - the one you have between pins 1 and 2, so you can remove that.
Which version of the IDE are you using?
Do you get any errors when you compile the program? I have downloaded it and it compiles and works with a plain DHT11, but I am using 0022!
there must be a delay of 2 seconds between readings
delay(2000);
Serial.print(millis());
Serial.print("\t");
Serial.print(h);
Serial.print(t);
furthermore the DHT11 does return integers, no floats (but that cannot cause the problem)
you can try my DHT lib, it tells something about error conditions if they occur - Arduino Playground - DHTLib -
