DHT11 and Xively
Hi all, I have problem with this code- (DHT11 was no declared in this scope)
Can anyone tell me, where is the problem, please?
#include <SPI.h>
#include <Ethernet.h>
#include <HttpClient.h>
#include <VirtualWire.h>
#include <Xively.h>
#include "DHT.h"
#define DHTPIN 3     // PIN data of DHT22
#define DHTTYPE DHT11   // DHT 11
   // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
// MAC address for your Ethernet shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Your Xively key to let you upload data
char xivelyKey[] = "keykeykey";
// Define the strings for our datastream IDs
char sensorId1[] = "Temperature";
char sensorId2[] = "Humidity";
XivelyDatastream datastreams[] = {
  XivelyDatastream(sensorId1, strlen(sensorId1), DATASTREAM_FLOAT),
  XivelyDatastream(sensorId2, strlen(sensorId2), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed. Set the Feed value insted of 12345678
XivelyFeed feed(12345678, datastreams, 2 /* number of datastreams */);
EthernetClient client;
XivelyClient xivelyclient(client);
  Serial.println("Starting single datastream upload to Xively...");
  dht.begin();
  while (Ethernet.begin(mac) != 1)
    Serial.println("Error getting IP address via DHCP, trying again...");
    delay(15000);
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  float h = dht.readHumidity(); // Value of Temp
  float t = dht.readTemperature(); // Value of Humidity
  datastreams[0].setFloat(t); // Value of Temp
  datastreams[1].setFloat(h); // Value of Humidity
  Serial.print("Read sensor value ");
  Serial.println(datastreams[0].getFloat());
  Serial.println("Uploading it to Xively");
  // Send data to Xively
  int ret = xivelyclient.put(feed, xivelyKey);
  Serial.print("xivelyclient.put returned ");
  Serial.println(ret);
  delay(15000);
can you strip the program to only print the temperature from the DHT sensor? (no xively code)
which library do you use?
I used this library - https://github.com/adafruit/DHT-sensor-library thanks
please try my lib - https://github.com/RobTillaart/Arduino/tree/master/libraries/DHTlib - it has been confirmed to work on several Arduino boards.
