DHT11 calibration
Good day all,
I am putting together the final touches for my microclimate controller but have yet again hit another roadblock.
I have finally gotten my RTC light/fan timer working properly but today I tested my DHT11 sensor and i'm getting wild readout in the serial monitor.
0ˇDHTxx test! Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F Humidity: 947.20 % Temperature: 512.00 *C 953.60 *F Heat index: -45824.82 *C -82453.50 *F
Can anybody tell if this is just a bad sensor, or is there a way to calibrate this so that I get a correct reading?
Here is the test sketch that I'm using.
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN A3     // what digital pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
Or is there a possibility that my Arduino is trashed? I haven't had a chance to test this on my Mega2560 but sometimes that yields better results.
Try changing code to use DHT11 (instead of DHT22)
knut_ny: Try changing code to use DHT11 (instead of DHT22)
Haha OMG do I feel like an asset x_x
