DHT11, Keypad, and Dot Matrix LED Running Text
Hello,
Help me, why the scrolling text can’t looping after I pressed (*) and (#) button?
#include <MaxMatrix.h> //include matrix library
#include <avr/pgmspace.h>
#include <stdlib.h>
#include <dht.h>
dht DHT;
#define DHT11_PIN 50
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
//define the cymbols on the buttons of the keypads
char keypadArray[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {A3, A2, A1, A0}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {3, 4, 5, 6}; //connect to the column pinouts of the keypad
//initialize an instance of the Keypad class
Keypad myKeypad = Keypad(makeKeymap(keypadArray), rowPins, colPins, ROWS, COLS);
PROGMEM const unsigned char CH[] = {
5, 8, B01100011, B00010011, B00001000, B01100100, B01100011, // %
3, 8, B00000010, B00000101, B00000010, B00000000, B00000000, // '
2, 8, B01010000, B00000000, B00000000, B00000000, B00000000, // :
4, 8, B01111110, B00010001, B00010001, B01111110, B00000000, // A
4, 8, B01111111, B01001001, B01001001, B00110110, B00000000, // B
4, 8, B00111110, B01000001, B01000001, B00100010, B00000000, // C
4, 8, B01111111, B01000001, B01000001, B00111110, B00000000, // D
4, 8, B01111111, B01001001, B01001001, B01000001, B00000000, // E
4, 8, B01111111, B00001001, B00001001, B00000001, B00000000, // F
4, 8, B00111110, B01000001, B01001001, B01111010, B00000000, // G
4, 8, B01111111, B00001000, B00001000, B01111111, B00000000, // H
3, 8, B01000001, B01111111, B01000001, B00000000, B00000000, // I
4, 8, B00110000, B01000000, B01000001, B00111111, B00000000, // J
4, 8, B01111111, B00001000, B00010100, B01100011, B00000000, // K
4, 8, B01111111, B01000000, B01000000, B01000000, B00000000, // L
5, 8, B01111111, B00000010, B00001100, B00000010, B01111111, // M
5, 8, B01111111, B00000100, B00001000, B00010000, B01111111, // N
4, 8, B00111110, B01000001, B01000001, B00111110, B00000000, // O
4, 8, B01111111, B00001001, B00001001, B00000110, B00000000, // P
4, 8, B00111110, B01000001, B01000001, B10111110, B00000000, // Q
4, 8, B01111111, B00001001, B00001001, B01110110, B00000000, // R
4, 8, B01000110, B01001001, B01001001, B00110010, B00000000, // S
5, 8, B00000001, B00000001, B01111111, B00000001, B00000001, // T
4, 8, B00111111, B01000000, B01000000, B00111111, B00000000, // U
5, 8, B00001111, B00110000, B01000000, B00110000, B00001111, // V
5, 8, B00111111, B01000000, B00111000, B01000000, B00111111, // W
5, 8, B01100011, B00010100, B00001000, B00010100, B01100011, // X
5, 8, B00000111, B00001000, B01110000, B00001000, B00000111, // Y
4, 8, B01100001, B01010001, B01001001, B01000111, B00000000, // Z
2, 8, B01111111, B01000001, B00000000, B00000000, B00000000, // [
4, 8, B00100000, B01010100, B01010100, B01111000, B00000000, // a
4, 8, B01111111, B01000100, B01000100, B00111000, B00000000, // b
4, 8, B00111000, B01000100, B01000100, B00101000, B00000000, // c
4, 8, B00111000, B01000100, B01000100, B01111111, B00000000, // d
4, 8, B00111000, B01010100, B01010100, B00011000, B00000000, // e
3, 8, B00000100, B01111110, B00000101, B00000000, B00000000, // f
4, 8, B10011000, B10100100, B10100100, B01111000, B00000000, // g
4, 8, B01111111, B00000100, B00000100, B01111000, B00000000, // h
3, 8, B01000100, B01111101, B01000000, B00000000, B00000000, // i
4, 8, B01000000, B10000000, B10000100, B01111101, B00000000, // j
4, 8, B01111111, B00010000, B00101000, B01000100, B00000000, // k
3, 8, B01000001, B01111111, B01000000, B00000000, B00000000, // l
5, 8, B01111100, B00000100, B01111100, B00000100, B01111000, // m
4, 8, B01111100, B00000100, B00000100, B01111000, B00000000, // n
4, 8, B00111000, B01000100, B01000100, B00111000, B00000000, // o
4, 8, B11111100, B00100100, B00100100, B00011000, B00000000, // p
4, 8, B00011000, B00100100, B00100100, B11111100, B00000000, // q
4, 8, B01111100, B00001000, B00000100, B00000100, B00000000, // r
4, 8, B01001000, B01010100, B01010100, B00100100, B00000000, // s
3, 8, B00000100, B00111111, B01000100, B00000000, B00000000, // t
4, 8, B00111100, B01000000, B01000000, B01111100, B00000000, // u
5, 8, B00011100, B00100000, B01000000, B00100000, B00011100, // v
5, 8, B00111100, B01000000, B00111100, B01000000, B00111100, // w
5, 8, B01000100, B00101000, B00010000, B00101000, B01000100, // x
4, 8, B10011100, B10100000, B10100000, B01111100, B00000000, // y
3, 8, B01100100, B01010100, B01001100, B00000000, B00000000, // z
int data = 10;    // DIN pin of MAX7219 module
int load = 11;    // CS pin of MAX7219 module
int clck = 12;  // CLK pin of MAX7219 module
int maxInUse = 4;    //change this variable to set how many MAX7219's you'll use
MaxMatrix m(data, load, clck, maxInUse); // define module
byte buffer[10];
void setup(){
  m.init(); // module initialize
  m.setIntensity(2); // dot matix intensity 0-15
  Serial.begin(9600); // serial communication initialize
  Serial.println("DHTxx test!");
 // dht.begin();
void loop(){
 char key = myKeypad.getKey();
int chk = DHT.read11(DHT11_PIN);
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
int t = DHT.temperature;
int v = DHT.humidity;
char temp[4];
char hum[4];
itoa(t,temp,10); //convert int to char!!!!
itoa(v,hum,10);
Serial.println(temp);
  if(key == '*')
    printStringWithShift("Teperature: ", 100);
    printStringWithShift(temp, 100);
    printStringWithShift("'C   ", 100);
    printStringWithShift("Status: ", 100);
    if(t >= 30)
     printStringWithShift("Warm  ", 100);
    printStringWithShift("Normal  ", 100);
  else if(key == '#')
  printStringWithShift("Humidity: ", 100);
  printStringWithShift(hum, 100);
  printStringWithShift("%H   ", 100);
  m.shiftLeft(false, true);
void printCharWithShift(char c, int shift_speed){
  if (c < 32) return;
  c -= 32;
  memcpy_P(buffer, CH + 7*c, 7);
  m.writeSprite(32, 0, buffer);
  m.setColumn(32 + buffer[0], 0);
  for (int i=0; i<buffer[0]+1; i++)
    delay(shift_speed);
    m.shiftLeft(false, false);
void printStringWithShift(char* s, int shift_speed){
  while (*s != 0){
    printCharWithShift(*s, shift_speed);
    s++;
void printString(char* s)
  int col = 0;
  while (*s != 0)
    if (*s < 32) continue;
    char c = *s - 32;
    m.writeSprite(col, 0, buffer);
    m.setColumn(col + buffer[0], 0);
    col += buffer[0] + 1;
    s++;
We have no idea what you are trying to say. What do you mean by "Running Text stops after the text is finished"? What do you mean by "I want the text keep running"?
If you can't describe your desired outcome in English, try showing us what your desired outcome would look like.
JaBa:
Sorry for my bad english.
I want LED matrix to display the temperature and humidity value if I press the keypad. Example (*) button for temperature and (#) for humidity.
Thank you.
Note: I edited my post and put the sketch
