DHT11 not work with ESP32
I buy my DHT11 from this shop
https://www.jaycar.com.au/arduino-compatible-temperature-and-humidity-sensor-module/p/XC4520
I could not get any data from the sensor, only got nan . I have check my connection plenty of times. I also check my code and use many example code from internet and example from arduino IDE. All the result came out as nan
When i measure voltage across the Vcc and ground of sensor , it shows 5V supply which is good because sensor DHT11 could accept both 3.3 -5V . However , when i measure the voltage across digital pin and ground it only show 2.16V which not I expect because to read the DHT11 , the digital pin voltage should be larger than 3 V . Could you please give me some advice on this?
temperature.h
#ifndef temperature_h
#define temperature_h
extern float temperature_battery;
class temperature {
  public:
  void begin();
  void calculate_temperature();
#endif
temperature.cpp
#define turn_on_fan_pin 14
const int DHT_PIN = 17;
float temperature_battery ;
DHTesp dht;
void temperature::begin(){
  dht.setup(DHT_PIN, DHTesp::DHT11);
void temperature::calculate_temperature(){
  TempAndHumidity data = dht.getTempAndHumidity();
 temperature_battery = data.temperature;
  Serial.println("my temperature");
  Serial.println ( temperature_battery);
  if (temperature_battery > 25)
    digitalWrite( turn_on_fan_pin, HIGH);
  else {
      digitalWrite( turn_on_fan_pin, LOW);
charge.cpp
#include "charge.h"
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads(0x48);
#define voltage_read_pin 34
#define cut_off_pin 16
float total_cell_charge;
float cell[3];
int percentage_value;
float current_cell[3];
float total_current;
int count_time = 0 ;
volatile boolean interrupt_timer0;
hw_timer_t * timer0 = NULL;
portMUX_TYPE timerMux0 = portMUX_INITIALIZER_UNLOCKED;
void IRAM_ATTR onTimer0() {
  portENTER_CRITICAL_ISR(&timerMux0);
  interrupt_timer0 = true;
  portEXIT_CRITICAL_ISR(&timerMux0);
void charge::begin(){
   ads.begin();
  timer0 = timerBegin(0, 80, true);
  timerAttachInterrupt(timer0 , &onTimer0, true);
  timerAlarmWrite(timer0, 2000000, true);
  timerAlarmEnable(timer0);
void charge::voltage_read (void){
  if (interrupt_timer0 = true) {
    portENTER_CRITICAL(&timerMux0);
    portEXIT_CRITICAL(&timerMux0);
     for (int i = 0; i < 3; i++)
        Serial.println("My voltage is ");
        float cell_temp =  analogRead(voltage_read_pin)*3.3/4095;
        cell[i] =  cell_temp *10;
        Serial.println(cell_temp);
        int16_t  adc_temp  = ads.readADC_SingleEnded(0);
        current_cell[i] =  adc_temp *100/0.075;
        Serial.println("My current ");
        Serial.println(current_cell[1]);
    interrupt_timer0 = false;
void charge::check_voltage(){
  Serial.println("total_cell");
  total_cell_charge = (cell[0]+cell[1]+cell[2])/3 ;
  Serial.println (total_cell_charge);
  if (total_cell_charge > 27 ) {
    digitalWrite(cut_off_pin, HIGH);
  else if (total_cell_charge < 16 ) {
    digitalWrite(cut_off_pin,HIGH);
  else{
    digitalWrite(cut_off_pin, LOW);
void charge::percentage(){
  if (total_cell_charge >= 27 ){
    percentage_value = 100 ;
  else if (total_cell_charge < 27 and total_cell_charge > 26 ){
    percentage_value = 95 ;
  else if (total_cell_charge <= 26 and total_cell_charge > 25 ){
    percentage_value = 90 ;
  else if (total_cell_charge <= 25 and total_cell_charge > 24.5 ){
    percentage_value = 85 ;
  else if (total_cell_charge <= 24.5 and total_cell_charge > 23.5 ){
    percentage_value = 80 ;
  else if (total_cell_charge <= 23.5 and total_cell_charge > 23 ){
    percentage_value = 75 ;
  else if (total_cell_charge <= 23 and total_cell_charge > 22.8 ){
    percentage_value = 70 ;
  else if (total_cell_charge <= 22.8 and total_cell_charge > 22.5 ){
    percentage_value = 65 ;
  else if (total_cell_charge <= 22.5 and total_cell_charge > 22 ){
    percentage_value = 60 ;
  else if (total_cell_charge <= 22 and total_cell_charge > 21.8 ){
    percentage_value = 55 ;
   else if (total_cell_charge <= 21.8 and total_cell_charge > 21.5 ){
    percentage_value = 50 ;
   else if (total_cell_charge <= 21.5 and total_cell_charge > 21.3 ){
    percentage_value = 45 ;
   else if (total_cell_charge <= 21.3 and total_cell_charge > 21 ){
    percentage_value = 35 ;
  else if (total_cell_charge <= 21 and total_cell_charge > 20.9 ){
    percentage_value = 30 ;
  else if (total_cell_charge <= 20.8 and total_cell_charge > 20.5 ){
    percentage_value = 25 ;
  else if (total_cell_charge <= 20.5 and total_cell_charge > 20 ){
    percentage_value = 20 ;
  else if (total_cell_charge <= 20 and total_cell_charge > 19.8 ){
    percentage_value = 10 ;
  else {
   percentage_value = 0 ;
void charge:: check_current(){
  total_current =  (current_cell[0] +current_cell[1]+current_cell[2] )/3;
  if (total_current > 27 )
  else {
     digitalWrite(cut_off_pin,LOW);
charge.h
#ifndef charge_h
#define charge_h
extern int percentage_value;
extern float total_cell_charge;
class charge {
  public:
  void begin();
  void check_voltage();
  void voltage_read (void);
  void percentage();
  void check_current();
  void current_read (void);
#endif
main.ino
#include "temperature.h"
#include "charge.h"
#include <Wire.h>
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <AsyncTCP.h>
#include "SPIFFS.h"
// Replace with your network credentials
const char* ssid = "ChiNghiep";
const char* password = "Chihai2411";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String temperature_text;
String percentage_text = "42";
temperature bms;
charge  battery ;
  Serial.println("Hello!");
  // Initialize SPIFFS
  if(!SPIFFS.begin()){
    Serial.println("An Error has occurred while mounting SPIFFS");
    return;
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  // Print ESP32 Local IP Address
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(SPIFFS, "/index.html");
  server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", temperature_text.c_str());
  server.on("/percentage", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain",  percentage_text.c_str());
  server.begin();
  battery.begin();
  bms.begin();
  temperature_text =String(temperature_battery);
  bms.calculate_temperature();
  battery.voltage_read ();
  battery.check_voltage();
  battery.percentage();
  battery.check_current();
SCHEMATIC HOW I CONNECT DHT11
Please post a schematic of your circuit. A picture of a hand drawn circuit is good enough
Post the code in code tags.
Post an image of your project.
Please.
Also this
is not correct.
i had add the schematic on question
I had add the code on the question
Why go back and edit the first post? It breaks the continuity of the thread. Please post new postings at the end instead of going back and editing.
Is the DHT you bought a 3.3V device or a 5V device? The ESP32 is a 3.3V device.
Good luck.
Sorry
I not sure . The back of the device said 3.3V-5V DC . The example that the store provide use 5V output of Arduino uno. But the esp32 have 5V pin isn't it ?
Sorry
