Hello everyone! Im making a project where I read the Temperature and Humidity with a DHT11, and I send those infos to a ThingSpeak channel using a NodeMCU ESP-32. The thing is: im able to send a counter to the channel, and the WiFi signal. Im also able to use the DHT11 sensor, reading the right temp/humi. But when I "adapted" the DHT11 code to the code where I send the infos to the TS channel, the sensor get crazy, reading wrong values and sometimes can't even read. Here are the codes that im using:
The DHT11 code (working fine):
// Example testing sketch for various DHT humidity/temperature sensors written by ladyada
// REQUIRES the following Arduino libraries:
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
// - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
#include "DHT.h"
#define DHTPIN 4 // Digital pin connected to the DHT sensor
// Feather HUZZAH ESP8266 note: use pins 3, 4, 5, 12, 13 or 14 --
// Pin 15 can work but DHT must be disconnected during program upload.
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors. This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
Serial.println(F("DHTxx test!"));
dht.begin();
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(f);
Serial.print(F("°F Heat index: "));
Serial.print(hic);
Serial.print(hif);
Serial.println(F("°F"));
The code where i adapted the sensor code to the internet connection:
#include <Arduino.h>
#include "WiFi.h"
#include "ThingSpeak.h"
#include "DHT.h"
#define DHTPIN 4
#define CHANNEL_ID 1399592
#define CHANNEL_API_KEY "31xxxxxX9QVFR0"
WiFiClient client;
int counter = 0;
#define WIFI_NETWORK "FGHN"
#define WIFI_PASSWORD "xxxxxxx"
#define WIFI_TIMEOUT_MS 20000
void connectToWiFi(){
Serial.print("Connecting to WiFi");
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_NETWORK, WIFI_PASSWORD);
unsigned long startAttemptTime = millis();
while(WiFi.status() != WL_CONNECTED && millis() - startAttemptTime < WIFI_TIMEOUT_MS){
Serial.print(".");
delay(100);
if(WiFi.status() != WL_CONNECTED){
Serial.println("Failed");
}else {
Serial.print("Conectado com Sucesso ao ip: ");
connectToWiFi();
ThingSpeak.begin(client);
return;
delay(2000);
Serial.print(h);
Serial.print(t);
Serial.print(f);
Serial.print(hic);
Serial.print(hif);
ThingSpeak.setField(1,h);
ThingSpeak.setField(2,t);
ThingSpeak.writeFields(CHANNEL_ID, CHANNEL_API_KEY);
delay(15000);
This is the error that i get:
............................................Conectado com Sucesso ao ip: 192.168.15.7
DHTxx test!
Any help will be much appreciated! Thanks!
