DHT11 Readings Showing Up on Serial Monitor, But Not LCD
I'm using an Arduino Uno with a DHT11 temperature and humidity sensor and a Liquid Crystal Display. I'm getting readings from the DHT11 that show up on the serial monitor. However, the readings don't show up on the LCD.
Why is that?
How can I fix it?
Here is my code:
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <LiquidCrystal.h>
const int rs = 2, en = 3, d4 = 4, d5 = 5, d6 = 6, d7 = 7;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define DHTPIN            10         // Pin which is connected to the DHT sensor.
#define DHTTYPE           DHT11     // DHT 11
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
  lcd.begin(16, 2);
  // Initialize device.
  dht.begin();
  Serial.println("DHTxx Unified Sensor Example");
  // Print temperature sensor details.
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  dht.humidity().getSensor(&sensor);
  delayMS = sensor.min_delay / 1000;
  lcd.setCursor(0, 0);
  lcd.print("Calibrating");
    for(int i = 0; i <10; i++){
      if (i==4)
         lcd.setCursor(0, 1);
         lcd.print(".");
       else  lcd.print(".");
    lcd.setCursor(5, 1);
    lcd.print("done");
    lcd.clear();
    lcd.setCursor(1, 0);
    lcd.print("SENSOR ACTIVE");
    delay(1500);
  // Delay between measurements.
  delay(delayMS);
  lcd.clear();
  // Get temperature event and print its value.
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println("Error reading temperature!");
  else {
    lcd.print("Temp : ");
    Serial.print("Temperature: ");
    Serial.print(event.temperature);
    lcd.print(event.temperature);
    Serial.println(" *C");
    lcd.write(0xdf);      // for dgree sign
    lcd.print("C ");
  // Get humidity event and print its value.
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println("Error reading humidity!");
  else {
    lcd.print("Humidity: ");
    Serial.print("Humidity: ");
    Serial.print(event.relative_humidity);
    lcd.print(event.relative_humidity);
    lcd.print("%");
    Serial.println("%");
Hello
You can use the following code:
I've tried it and it works correctly
#include <dht.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int greenPin = A0;
dht sensor;
  lcd.begin(16,2); //16 by 2 character display
  delay(1000); //wait a sec (recommended for DHT11)
  sensor.read11(greenPin);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Humidity = ");
  lcd.print(sensor.humidity);
  lcd.setCursor(0,1);
  lcd.print("Temp = ");
  lcd.print(sensor.temperature);
mayamac-seid:
I have executed your posted codes (without any change) on the Arduino MEGA and LCD. The Serial Monitor and LCD are showing normal values of Temperature and Humidity.
Please, check the wiring and the healthiness of your LCD.
