DHT11 Sensor Scroll on lcd shield
Hi, its ya boi ah Arduino_Begginnger_13(spelt so wrong)
Right enough of the crap(lol)
So I have An Arduino r3 on an LCD keypad shield. I have the top line of the 2x16 character LCD
Is the temp and humidity from the dht11 and on the bottom line I would like to have a scroll feature on this text= Baileys Electronics Shed = I hope someone can add this into the code for me. If this is not clear I can make it easy to understand if need be.
chur
Bailey
No, because you forgot to post the code that have this problem. And as you're not a beginner on the forum (9 posts) you should know to use code tags.
here it is
WeatherStation1.zip (619 Bytes)
Try integrate something like this (this is not finished code, you have to adapt it to your needs):
char mystr[] = "This is the scrolling text in the display";
char *ptr = mystr;
while (*ptr) {
  lcd.setCursor(0,1);
  lcd.print(ptr);
  ptr++;
