Hallo,
brauche Hilfe. Ich versuche Temperatur und Feuchtigkeit an Thingspeak zu schicken, aber das Programm läuft nicht richtig.
Es kommt immer die Fehlermeldung "expected primary-expression befor '.' token", wie im Foto zu erkennen
#include <SPI.h>
#include <Ethernet.h>
#include <DHT11.h>
#include <Wire.h>
#include <Adafruit_BMP085.h> // This is the version 1 library
#define DHT11PIN 4 // The Temperature/Humidity sensor
Adafruit_BMP085 bmp;
// Local Network Settings
byte mac[] = { 0xD4, 0x28, 0xB2, 0xFF, 0xA0, 0xA1 }; // Must be unique on local network
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
String writeAPIKey = "REPLACE_THIS_BY_YOUR_API_BUT_KEEP_THE_QUOTES";
const int updateThingSpeakInterval = 16 * 1000; // Time interval in milliseconds to update ThingSpeak (number of seconds * 1000 = interval)
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
int failedCounter = 0;
// Initialize Arduino Ethernet Client
EthernetClient client;
// Start Serial for debugging on the Serial Monitor
// Start Ethernet on Arduino
startEthernet();
// Read value from Analog Input Pin 0
String analogPin0 = String(analogRead(A0), DEC);
// Print Update Response to Serial Monitor
if (client.available())
char c = client.read();
Serial.print(c);
//------DHT11--------
int chk = DHT11.read(DHT11PIN);
char t_buffer[10];
char h_buffer[10];
float t=(DHT11.temperature);
String temp=dtostrf(t,0,5,t_buffer);
//Serial.print(temp);
//Serial.print(" ");
[color=red]float h=(DHT11.humidity);[/color]
String humid=dtostrf(h,0,5,h_buffer);
//Serial.println(humid);
//-----BMP180-----------
bmp.begin();
float p=(bmp.readPressure()/100.0);//this is for pressure in hectoPascal
float m=(bmp.readPressure()/133.3);// this is for pressure in mmHG
float t2=(bmp.readTemperature());
char p_buffer[15];
char t2_buffer[10];
String pres=dtostrf(p,0,5,p_buffer);
String temp2=dtostrf(t2,0,5,t2_buffer);
Serial.println(pres);
// Disconnect from ThingSpeak
if (!client.connected() && lastConnected)
Serial.println("...disconnected");
client.stop();
// Update ThingSpeak
if(!client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval))
updateThingSpeak("field1="+temp+"&field2="+humid+"&field3="+pres+"&field4="+temp2);
// Check if Arduino Ethernet needs to be restarted
if (failedCounter > 3 ) {startEthernet();}
lastConnected = client.connected();
void updateThingSpeak(String tsData)
if (client.connect(thingSpeakAddress, 80))
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "+writeAPIKey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(tsData.length());
client.print("\n\n");
client.print(tsData);
lastConnectionTime = millis();
if (client.connected())
Serial.println("Connecting to ThingSpeak...");
failedCounter = 0;
failedCounter++;
Serial.println("Connection to ThingSpeak failed ("+String(failedCounter, DEC)+")");
failedCounter++;
Serial.println("Connection to ThingSpeak Failed ("+String(failedCounter, DEC)+")");
void startEthernet()
client.stop();
Serial.println("Connecting Arduino to network...");
// Connect to network amd obtain an IP address using DHCP
if (Ethernet.begin(mac) == 0)
Serial.println("DHCP Failed, reset Arduino to try again");
Serial.println("Arduino connected to network using DHCP");
