DHT11 temp sensor combined with ultrasonic sensor code bug?
I am trying to combine a temperature sensor, the DHT11, with the HC-SR04 ultrasonic sensor to get very accurate distance measurements. This is because the speed of sound varies in different temperatures. Here is the code I have.
//This is useful because as the temperature increases, the speed of sound also increases. With this, you can be more precise about your distance measurements.
//The formula is: c = 331.3 + T(Celcius) * 0.606 m/s
#include <dht11.h>
#include <Versalino.h>
dht11 DHT11;
int celciusTemp;
#define trigPin 8
#define echoPin 7
long duration, distance, c;            //c is the speed of sound
void setup(){
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
 DHT11.attach(3);
void loop(){
 int check = DHT11.read();
 switch(check){
  case 0: Serial.println("DHT11 OK"); break;
  case -1: Serial.println("DHT11 Checksum error"); break;
  case -2: Serial.println("DHT11 Time out error"); break;
  default: Serial.println("DHT11 unknown error"); break;
 //fire the ultrasonic and get the time interval between send/receive
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  //get the temp in celcius (default)
  celciusTemp = (int)DHT11.temperature;
  //calculate the speed of sound based on value from temp sensor
  c = 331.3 + celciusTemp * 0.606;
  //calculate the distance from duration and speed of sound
  distance = c * duration;
 Serial.println("Temperature = " + celciusTemp);
 Serial.println("Speed of sound = " + c);
 Serial.println("Distance = " + distance);
 delay(2000);            //this is slow because the DHT11 can't be clocked over 1 reading per 2 seconds
But when I open the serial monitor I'm just getting random gibberish and the program freezes (I have to force exit with ctrl-alt-del). Any suggestions?
After you do a Serial.begin print something like "Starting".
Maybe you have the baud rate wrong in the serial monitor.
You cannot concatenate text and variables together and print the like this. Print each one separately or concatenate them first using sprintf()
Well spotted, I missed that one. That would indeed print garbage. You could also use the Streaming library:
http://arduiniana.org/libraries/streaming/
Ah of course, I forgot about the concatenation rules.
Also the streaming library works great!
Thanks all
