DHT11 temperature sensor
hy,
I have a small problem using DH11, I got the sample code from the internet and when uploading it and looking at serial monitor I am getting -999 value for both temp and humidity
#include <dht.h>
dht DHT;
#define DHT11_PIN 8
void setup(){
void loop(){
int chk = DHT.read11(DHT11_PIN);
Serial.print("Temperature = ");
Serial.println(DHT.temperature);
Serial.print("Humidity = ");
Serial.println(DHT.humidity);
It's long ago that I worked with the DTH. You can print the value of chk; from memory it's an error code that you can find back in the source code of the library. 0 would mean "no error".
Hello
Take a look into the IDE.
There you will find a example sketch named DHTtester to check your hardware.
Hi Blue10,
Did you mount a pull up resistor? A DHT11 needs 10k pull up.
Wiring scheme is available on (1) Bare DHT11 temperature and relative humidity sensor - Zonnestroompanelen in Nederland
success, Photoncatcher
