DHT11 Things Of Speak IOt
I have tested the code on local webserver , Now i am implementing for Things of speak.
Here is my code.
I have entered AP Key from web . If i open SerialPort it shows Its connected to wifi and waiting .I have send screen shot . Is there any issue related to code
The data to Webserver is Not updating is issue.
#include "DHT.h"
DHT dht;
#include <ESP8266WiFi.h>
String apiKey = "5IC43XY19CO9P6NC";     //  Enter your Write API key from ThingSpeak
const char *ssid =  "esp8266";     // replace with your wifi ssid and wpa2 key
const char *pass =  "Test123456";
const char* server = "api.thingspeak.com";
#define DHTPIN 3         //pin where the dht11 is connected
//DHT dht(DHTPIN, DHT11);
WiFiClient client;
       delay(10);
       dht.setup(D3);   /* D1 is used for data communication */
       Serial.println("Connecting to ");
       Serial.println(ssid);
       WiFi.begin(ssid, pass);
      while (WiFi.status() != WL_CONNECTED)
            Serial.print(".");
      Serial.println("");
      Serial.println("WiFi connected");
float humidity = dht.getHumidity(); /* Get humidity value */
  float temperature = dht.getTemperature(); /* Get temperature value */
             /* if (isnan(h) || isnan(t))
                     Serial.println("Failed to read from DHT sensor!");
                      return;
                         if (client.connect(server,80))   //   "184.106.153.149" or api.thingspeak.com
                             String postStr = apiKey;
                             postStr +="&field1=";
                             postStr += String(temperature);
                             postStr +="&field2=";
                             postStr += String(humidity);
                             postStr += "\r\n\r\n";
                             client.print("POST /update HTTP/1.1\n");
                             client.print("Host: api.thingspeak.com\n");
                             client.print("Connection: close\n");
                             client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
                             client.print("Content-Type: application/x-www-form-urlencoded\n");
                             client.print("Content-Length: ");
                             client.print(postStr.length());
                             client.print("\n\n");
                             client.print(postStr);
                             Serial.print("Temperature: ");
                             Serial.print(temperature);
                             Serial.print(" degrees Celcius, Humidity: ");
                             Serial.print(humidity);
                             Serial.println("%. Send to Thingspeak.");
          client.stop();
          Serial.println("Waiting...");
  // thingspeak needs minimum 15 sec delay between updates, i've set it to 30 seconds
  delay(10000);
DHT11.cpp
#include "DHT.h"
void DHT::setup(uint8_t pin, DHT_MODEL_t model)
  DHT::pin = pin;
  DHT::model = model;
  DHT::resetTimer(); // Make sure we do read the sensor in the next readSensor()
  if ( model == AUTO_DETECT) {
    DHT::model = DHT22;
    readSensor();
    if ( error == ERROR_TIMEOUT ) {
      DHT::model = DHT11;
      // Warning: in case we auto detect a DHT11, you should wait at least 1000 msec
      // before your first read request. Otherwise you will get a time out error.
void DHT::resetTimer()
  DHT::lastReadTime = millis() - 3000;
float DHT::getHumidity()
  readSensor();
  return humidity;
float DHT::getTemperature()
  readSensor();
  return temperature;
#ifndef OPTIMIZE_SRAM_SIZE
const char* DHT::getStatusString()
  switch ( error ) {
    case DHT::ERROR_TIMEOUT:
      return "TIMEOUT";
    case DHT::ERROR_CHECKSUM:
      return "CHECKSUM";
    default:
      return "OK";
#else
// At the expense of 26 bytes of extra PROGMEM, we save 11 bytes of
// SRAM by using the following method:
prog_char P_OK[]       PROGMEM = "OK";
prog_char P_TIMEOUT[]  PROGMEM = "TIMEOUT";
prog_char P_CHECKSUM[] PROGMEM = "CHECKSUM";
const char *DHT::getStatusString() {
  prog_char *c;
  switch ( error ) {
      c = P_CHECKSUM; break;
      c = P_TIMEOUT; break;
    default:
      c = P_OK; break;
  static char buffer[9];
  strcpy_P(buffer, c);
  return buffer;
#endif
void DHT::readSensor()
  // Make sure we don't poll the sensor too often
  // - Max sample rate DHT11 is 1 Hz   (duty cicle 1000 ms)
  // - Max sample rate DHT22 is 0.5 Hz (duty cicle 2000 ms)
  unsigned long startTime = millis();
  if ( (unsigned long)(startTime - lastReadTime) < (model == DHT11 ? 999L : 1999L) ) {
    return;
  lastReadTime = startTime;
  temperature = NAN;
  humidity = NAN;
  // Request sample
  digitalWrite(pin, LOW); // Send start signal
  pinMode(pin, OUTPUT);
  if ( model == DHT11 ) {
    delay(18);
  else {
    // This will fail for a DHT11 - that's how we can detect such a device
    delayMicroseconds(800);
  pinMode(pin, INPUT);
  digitalWrite(pin, HIGH); // Switch bus to receive data
  // We're going to read 83 edges:
  // - First a FALLING, RISING, and FALLING edge for the start bit
  // - Then 40 bits: RISING and then a FALLING edge per bit
  // To keep our code simple, we accept any HIGH or LOW reading if it's max 85 usecs long
  uint16_t rawHumidity = 0;
  uint16_t rawTemperature = 0;
  uint16_t data = 0;
  for ( int8_t i = -3 ; i < 2 * 40; i++ ) {
    byte age;
    startTime = micros();
    do {
      age = (unsigned long)(micros() - startTime);
      if ( age > 90 ) {
        error = ERROR_TIMEOUT;
        return;
    while ( digitalRead(pin) == (i & 1) ? HIGH : LOW );
    if ( i >= 0 && (i & 1) ) {
      // Now we are being fed our 40 bits
      data <<= 1;
      // A zero max 30 usecs, a one at least 68 usecs.
      if ( age > 30 ) {
        data |= 1; // we got a one
    switch ( i ) {
      case 31:
        rawHumidity = data;
      case 63:
        rawTemperature = data;
        data = 0;
  // Verify checksum
  if ( (byte)(((byte)rawHumidity) + (rawHumidity >> 8) + ((byte)rawTemperature) + (rawTemperature >> 8)) != data ) {
    error = ERROR_CHECKSUM;
    return;
  // Store readings
    humidity = rawHumidity >> 8;
    temperature = rawTemperature >> 8;
  else {
    humidity = rawHumidity * 0.1;
    if ( rawTemperature & 0x8000 ) {
      rawTemperature = -(int16_t)(rawTemperature & 0x7FFF);
    temperature = ((int16_t)rawTemperature) * 0.1;
  error = ERROR_NONE;
DHT11.h
#ifndef dht_h
#define dht_h
#if ARDUINO < 100
  #include <WProgram.h>
#else
  #include <Arduino.h>
#endif
class DHT
public:
  typedef enum {
    AUTO_DETECT,
    DHT11,
    DHT22,
    AM2302,  // Packaged DHT22
    RHT03    // Equivalent to DHT22
  DHT_MODEL_t;
  typedef enum {
    ERROR_NONE = 0,
    ERROR_TIMEOUT,
    ERROR_CHECKSUM
  DHT_ERROR_t;
  void setup(uint8_t pin, DHT_MODEL_t model=AUTO_DETECT);
  void resetTimer();
  float getTemperature();
  float getHumidity();
  DHT_ERROR_t getStatus() { return error; };
  const char* getStatusString();
  DHT_MODEL_t getModel() { return model; }
  int getMinimumSamplingPeriod() { return model == DHT11 ? 1000 : 2000; }
  int8_t getNumberOfDecimalsTemperature() { return model == DHT11 ? 0 : 1; };
  int8_t getLowerBoundTemperature() { return model == DHT11 ? 0 : -40; };
  int8_t getUpperBoundTemperature() { return model == DHT11 ? 50 : 125; };
  int8_t getNumberOfDecimalsHumidity() { return 0; };
  int8_t getLowerBoundHumidity() { return model == DHT11 ? 20 : 0; };
  int8_t getUpperBoundHumidity() { return model == DHT11 ? 90 : 100; };
  static float toFahrenheit(float fromCelcius) { return 1.8 * fromCelcius + 32.0; };
  static float toCelsius(float fromFahrenheit) { return (fromFahrenheit - 32.0) / 1.8; };
protected:
  void readSensor();
  float temperature;
  float humidity;
  uint8_t pin;
private:
  DHT_MODEL_t model;
  DHT_ERROR_t error;
  unsigned long lastReadTime;
#endif /*dht_h*/
The documentation at thingspeak.com just shows an API on HTTPS. Why are you using port 80 for this?
