Hi! I have a problem with the DHT library in an assembly code
Can you help with that
This is the error message:
C:\Users\Mauricio\AppData\Local\Temp\build1496615171511360210.tmp\assemblycode.S.o: In function humedad': C:\Users\Mauricio\AppData\Local\Temp\build1496615171511360210.tmp/assemblycode.S:45: undefined reference to
dht'
collect2.exe: error: ld returned 1 exit status
Error de compilación
and this is the asm code:
.extern dht
.extern analogRead
.extern Arduino.h
.global setup
.global loop
setup:
cbi 0x14,2 //A2 Humedad
cbi 0x11,1 // A1 FotoCelda
cbi 0x11,0 // A0 Sen receptor
sbi 0x17,3 // D11 Leds Fondo
sbi 0x17,4 // D12 Led Noti Azul
sbi 0x17,5 // D13 Led Noti Rojo
ret
loop:
sbi 0x18,3
clr r24
clr r25
mov r24,1
mov r25,1
rcall analogRead
cpi r24,169
brmi foto
cbi 0x18,4
rjmp loop
foto:
clr r24
clr r25
mov r24,2
mov r25,2
rcall analogRead
cpi r24,247
brmi error
sbi 0x18,5
rjmp loop
humedad:
clr r24
clr r25
mov
rcall dht
//ldi r16, dht.readtemperature
error:
sbi 0x18,4
cbi 0x18,5
rjmp loop
