Hi everyone, I need someone to look at my set up and code, having problems to make it working the way I want.
What I am trying to do:
I want an RGB-LED indicate when the humidity, measured by a DHT11, exceeds certain ranges.
My current situation:
I have the DHT11 working and showing temperature and humidity via an LCD display. The RGB-LED is connected via 3 PWM ports and is glowing green, but it is not reacting to any humidity changes.
What I have tried so far:
- move the if/else-functions to different positions in the program loop
- use only one if/else-function
- replace the RGB-LED with three separate LEDs
- use digitalWrite instead of analogWrite
nothing of the above has helped.
I really hope someone has an idea what is wrong with my code/setup...
See attachement for schematics
The code:
#include <LiquidCrystal.h>
#include <dht_nonblocking.h>
#define DHT_SENSOR_TYPE DHT_TYPE_11
#define BLUE 3
#define GREEN 5
#define RED 6
static const int DHT_SENSOR_PIN = 2;
DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("temp. & humidity:");
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
digitalWrite(RED, LOW);
digitalWrite(GREEN, LOW);
digitalWrite(BLUE, LOW);
int redValue;
int greenValue;
int blueValue;
static bool measure_environment( float *temperature, float *humidity )
static unsigned long measurement_timestamp = millis( );
/* Measure once every four seconds. */
if ( millis( ) - measurement_timestamp > 3000ul )
if ( dht_sensor.measure( temperature, humidity ) == true )
return ( true );
return ( false );
float temperature = 25.0;
float humidity = 50.0;
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
if ( measure_environment( &temperature, &humidity ) == true )
lcd.print( "T=" );
lcd.print( temperature, 0 );
lcd.print( ", H=" );
lcd.print( humidity, 0 );
if (40.0 < humidity < 60.0)
if (45.0 < humidity < 55.0)
analogWrite(RED, 0),
analogWrite(GREEN, 20),
analogWrite(BLUE, 0);
analogWrite(RED, 30),
analogWrite(RED, 20),
analogWrite(GREEN, 0),
Thanks for any input!
