DHT11
hey guys I need to put DHT11 readings into a separate data location and discovered its reading zero but read's correctly when I read it directly using Serial.print(DHT.humidity); Serial.print(",\t"); Serial.println(DHT.temperature,1); into the serial monitor but if putting it into a data space then I get 0 0 reading can anyone help out.
Don;t understand what that means. Do you mean something like: float humidity = DHT.humidity;?
yep wanted to read temperature and humidity than send it over a wireless radio but all have had is zero
Then, clearly, the code you haven't posted is wrong. Fix it.
Also, identify the wireless method you are trying to use (nRF24, wifi, ?). Without proper information we can't help
Am using 433 wireless radio see sample
wanted to transmit both temperature and humidity
Jinmiolu: Am using 433 wireless radio see sample http://www.instructables.com/id/RF-315433-MHz-Transmitter-receiver-Module-and-Ardu/ wanted to transmit both temperature and humidity
Do we need to whack you with a clue-by-four? Where is your code?
