DHT22 BUS_Hung Problem
Hi there
I've been working on a school projects for weeks and I need to save the measurements of humidity and temperature.
I am using an Arduino Uno with an Ethernet Shield 2 and I copied the mounting of the DHT22 with a pullup resistor.
The monitor sends receiving data... BUS Hung and I don't find any answer nor explanation to this issue and my teacher won't try to help me.
Thanks in advance.
#include "DHT22.h"
// Only used for sprintf
#include <stdio.h>
// Data wire is plugged into port 7 on the Arduino
// Connect a 4.7K resistor between VCC and the data pin (strong pullup)
#define DHT22_PIN 7
// Setup a DHT22 instance
DHT22 myDHT22(DHT22_PIN);
void setup(void)
// start serial port
Serial.println("DHT22 Library Demo");
void loop(void)
DHT22_ERROR_t errorCode;
// The sensor can only be read from every 1-2s, and requires a minimum
// 2s warm-up after power-on.
delay(2000);
Serial.print("Requesting data...");
errorCode = myDHT22.readData();
switch(errorCode)
case DHT_ERROR_NONE:
Serial.print("Got Data ");
Serial.print(myDHT22.getTemperatureC());
Serial.print("C ");
Serial.print(myDHT22.getHumidity());
Serial.println("%");
// Alternately, with integer formatting which is clumsier but more compact to store and
// can be compared reliably for equality:
char buf[128];
sprintf(buf, "Integer-only reading: Temperature %hi.%01hi C, Humidity %i.%01i %% RH",
myDHT22.getTemperatureCInt()/10, abs(myDHT22.getTemperatureCInt()%10),
myDHT22.getHumidityInt()/10, myDHT22.getHumidityInt()%10);
Serial.println(buf);
case DHT_ERROR_CHECKSUM:
Serial.print("check sum error ");
Serial.print("C ");
case DHT_BUS_HUNG:
Serial.println("BUS Hung ");
case DHT_ERROR_NOT_PRESENT:
Serial.println("Not Present ");
case DHT_ERROR_ACK_TOO_LONG:
Serial.println("ACK time out ");
case DHT_ERROR_SYNC_TIMEOUT:
Serial.println("Sync Timeout ");
case DHT_ERROR_DATA_TIMEOUT:
Serial.println("Data Timeout ");
case DHT_ERROR_TOOQUICK:
Serial.println("Polled to quick ");
I would have expected "Requesting data..." and "BUS Hung". The sketch doesn't contain the string "receiving data...". Did you use the same sketch for testing?
Have you tried another DHT library than the Arduino-DHT22 you seem to be using (it was your job to provide that link!)? You library is doing rather uncommon things so it might be a non-working library. Try the Adafruit DHT library available in the IDE library manager.
