DHT22 CHECKSUM_ERROR after upgrade to IDE 1.6.1
Hello,
After upgrading the IDE from 1.0.6 to 1.6.1 i have a problem with my DHT22 sensor.
All worked ok with IDE 1.0.6 but after compiling the exact same sketch with 1.6.1
i got this error:
Requesting data…check sum error 1661.40C 48.40%
Requesting data…check sum error 843.80C 48.40%
Requesting data…check sum error 433.40C 2187.60%
Board: Arduino Mega2560
OS: XP
Any ideas ?
Thanks, Ed.
My code:
#include <DHT22.h>
// Only used for sprintf
#include <stdio.h>
// Data wire is plugged into port 7 on the Arduino
// Connect a 4.7K resistor between VCC and the data pin (strong pullup)
#define DHT22_PIN 7
// Setup a DHT22 instance
DHT22 myDHT22(DHT22_PIN);
void setup(void)
  // start serial port
  Serial.println("DHT22 Library Demo");
void loop(void)
  DHT22_ERROR_t errorCode;
  // The sensor can only be read from every 1-2s, and requires a minimum
  // 2s warm-up after power-on.
  delay(6000);
  Serial.print("Requesting data...");
  errorCode = myDHT22.readData();
  switch(errorCode)
    case DHT_ERROR_NONE:
      Serial.print("Got Data ");
      Serial.print(myDHT22.getTemperatureC());
      Serial.print("C ");
      Serial.print(myDHT22.getHumidity());
      Serial.println("%");
      // Alternately, with integer formatting which is clumsier but more compact to store and
	  // can be compared reliably for equality:
      char buf[128];
      sprintf(buf, "Integer-only reading: Temperature %hi.%01hi C, Humidity %i.%01i %% RH",
                   myDHT22.getTemperatureCInt()/10, abs(myDHT22.getTemperatureCInt()%10),
                   myDHT22.getHumidityInt()/10, myDHT22.getHumidityInt()%10);
      Serial.println(buf);
    case DHT_ERROR_CHECKSUM:
      Serial.print("check sum error ");
      Serial.print("C ");
    case DHT_BUS_HUNG:
      Serial.println("BUS Hung ");
    case DHT_ERROR_NOT_PRESENT:
      Serial.println("Not Present ");
    case DHT_ERROR_ACK_TOO_LONG:
      Serial.println("ACK time out ");
    case DHT_ERROR_SYNC_TIMEOUT:
      Serial.println("Sync Timeout ");
    case DHT_ERROR_DATA_TIMEOUT:
      Serial.println("Data Timeout ");
    case DHT_ERROR_TOOQUICK:
      Serial.println("Polled to quick ");
Try another library like my DHT library 0.1.13 version attached to first post of this thread
later version contain lower clock speed and footprint optimizations.
