DHT22 humidity, temp sensor not reading values.
Hello everyone,
I am using DHT22 sensor for humidity and temperature. I have a problems with this sensor as it seems that dht.readTemeperature and dht.readHumidity are not working. Ive tried to read the sensor value through analogRead() and some vlaues were returned so the sensor is fine.
When I use the Dragino Lora shield and the given code from them there is a problem. The code is as follows
  Require Library:
  https://github.com/dragino/RadioHead
  Upload Data to IoT Server ThingSpeak (https://thingspeak.com/):
  Support Devices: LoRa Shield + Arduino
  Example sketch showing how to read Temperature and Humidity from DHT11 sensor,
  Then send the value to LoRa Gateway, the LoRa Gateway will send the value to the
  IoT server
  It is designed to work with the other sketch dht11_server.
  modified 24 11 2016
  by Edwin Chen <support@dragino.com>
  Dragino Technology Co., Limited
#include <SPI.h>
#include <RH_RF95.h>
RH_RF95 rf95;
#define dht_dpin A0 // Use A0 pin as Data pin for DHT11.
byte bGlobalErr;
char dht_dat[5]; // Store Sensor Data
char node_id[3] = {1,1,1}; //LoRa End Node ID
float frequency = 868.0;
unsigned int count = 1;
    InitDHT();
    if (!rf95.init())
        Serial.println("init failed");
    // Setup ISM frequency
    rf95.setFrequency(frequency);
    // Setup Power,dBm
    rf95.setTxPower(13);
    rf95.setSyncWord(0x34);
    Serial.println("LoRa End Node Example --");
    Serial.println("    DHT11 Temperature and Humidity Sensor\n");
    Serial.print("LoRa End Node ID: ");
    for(int i = 0;i < 3; i++)
        Serial.print(node_id[i],HEX);
void InitDHT()
    pinMode(dht_dpin,OUTPUT);//Set A0 to output
    digitalWrite(dht_dpin,HIGH);//Pull high A0
//Get Sensor Data
void ReadDHT()
    bGlobalErr=0;
    byte dht_in;
    byte i;
    //pinMode(dht_dpin,OUTPUT);
    digitalWrite(dht_dpin,LOW);//Pull Low A0 and send signal
    delay(30);//Delay > 18ms so DHT11 can get the start signal
    delayMicroseconds(40);//Check the high level time to see if the data is 0 or 1
    pinMode(dht_dpin,INPUT);
    // delayMicroseconds(40);
    dht_in=digitalRead(dht_dpin);//Get A0 Status
    //   Serial.println(dht_in,DEC);
    if(dht_in){
        bGlobalErr=1;
        return;
    delayMicroseconds(80);//DHT11 send response, pull low A0 80us
    if(!dht_in){
        bGlobalErr=2;
        return;
    for (i=0; i<5; i++)//Get sensor data
    dht_dat[i] = read_dht_dat();
    digitalWrite(dht_dpin,HIGH);//release signal and wait for next signal
    byte dht_check_sum = dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];//calculate check sum
    if(dht_dat[4]!= dht_check_sum)//check sum mismatch
        {bGlobalErr=3;}
byte read_dht_dat(){
    byte i = 0;
    byte result=0;
    for(i=0; i< 8; i++)
        while(digitalRead(dht_dpin)==LOW);//wait 50us
        delayMicroseconds(30);//Check the high level time to see if the data is 0 or 1
        if (digitalRead(dht_dpin)==HIGH)
        result |=(1<<(7-i));//
        while (digitalRead(dht_dpin)==HIGH);//Get High, Wait for next data sampleing.
    return result;
uint16_t calcByte(uint16_t crc, uint8_t b)
    uint32_t i;
    crc = crc ^ (uint32_t)b << 8;
    for ( i = 0; i < 8; i++)
        if ((crc & 0x8000) == 0x8000)
            crc = crc << 1 ^ 0x1021;
            crc = crc << 1;
    return crc & 0xffff;
uint16_t CRC16(uint8_t *pBuffer,uint32_t length)
    uint16_t wCRC16=0;
    uint32_t i;
    if (( pBuffer==0 )||( length==0 ))
      return 0;
    for ( i = 0; i < length; i++)
      wCRC16 = calcByte(wCRC16, pBuffer[i]);
    return wCRC16;
    Serial.print("###########    ");
    Serial.print("COUNT=");
    Serial.print(count);
    Serial.println("    ###########");
    count++;
    ReadDHT();
    char data[50] = {0} ;
    int dataLength = 7; // Payload Length
    // Use data[0], data[1],data[2] as Node ID
    data[0] = node_id[0] ;
    data[1] = node_id[1] ;
    data[2] = node_id[2] ;
    data[3] = dht_dat[0];//Get Humidity Integer Part
    data[4] = dht_dat[1];//Get Humidity Decimal Part
    data[5] = dht_dat[2];//Get Temperature Integer Part
    data[6] = dht_dat[3];//Get Temperature Decimal Part
    switch (bGlobalErr)
      case 0:
          Serial.print("Current humidity = ");
          Serial.print(data[3], DEC);//Show humidity
          Serial.print(".");
          Serial.print(data[4], DEC);//Show humidity
          Serial.print("%  ");
          Serial.print("temperature = ");
          Serial.print(data[5], DEC);//Show temperature
          Serial.print(".");
          Serial.print(data[6], DEC);//Show temperature
          Serial.println("C  ");
       case 1:
          Serial.println("Error 1: DHT start condition 1 not met.");
       case 2:
          Serial.println("Error 2: DHT start condition 2 not met.");
       case 3:
          Serial.println("Error 3: DHT checksum error.");
       default:
          Serial.println("Error: Unrecognized code encountered.");
    uint16_t crcData = CRC16((unsigned char*)data,dataLength);//get CRC DATA
    //Serial.println(crcData,HEX);
    Serial.print("Data to be sent(without CRC): ");
    int i;
    for(i = 0;i < dataLength; i++)
        Serial.print(data[i],HEX);
        Serial.print(" ");
    unsigned char sendBuf[50]={0};
    for(i = 0;i < dataLength;i++)
        sendBuf[i] = data[i] ;
    sendBuf[dataLength] = (unsigned char)crcData; // Add CRC to LoRa Data
    sendBuf[dataLength+1] = (unsigned char)(crcData>>8); // Add CRC to LoRa Data
    Serial.print("Data to be sent(with CRC):    ");
    for(i = 0;i < (dataLength +2); i++)
        Serial.print(sendBuf[i],HEX);
        Serial.print(" ");
    rf95.send(sendBuf, dataLength+2);//Send LoRa Data
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];//Reply data array
    uint8_t len = sizeof(buf);//reply data length
    if (rf95.waitAvailableTimeout(3000))// Check If there is reply in 3 seconds.
        // Should be a reply message for us now
        if (rf95.recv(buf, &len))//check if reply message is correct
            if(buf[0] == node_id[0] && buf[1] == node_id[2] && buf[2] == node_id[2] ) // Check if reply message has the our node ID
               pinMode(4, OUTPUT);
               digitalWrite(4, HIGH);
               Serial.print("Got Reply from Gateway: ");//print reply
               Serial.println((char*)buf);
               delay(400);
               digitalWrite(4, LOW);
               //Serial.print("RSSI: ");  // print RSSI
               //Serial.println(rf95.lastRssi(), DEC);
           Serial.println("recv failed");//
           rf95.send(sendBuf, strlen((char*)sendBuf));//resend if no reply
        Serial.println("No reply, is LoRa gateway running?");//No signal reply
        rf95.send(sendBuf, strlen((char*)sendBuf));//resend data
    delay(30000); // Send sensor data every 30 seconds
    Serial.println("");
I have tried to use examples of DHT22 sketches and it is still not working. I cant figure it out where is the problem.
Thank you in advance!
Please attache the code here in the forum window and use code tags. I can't open Your code this way.
Thank you. The code is posted now.
SvetoslavG:
That doesn't mean anything. Even with nothing connected to an analog input you will get a value through analogRead().
Does your sensor work with the most basic DHT22 test sketch, that comes with the library you use?
Hello, thank you for your reply! Yes ive tried it with the vary basic dht example sketchet and it is still not working. A minute ago I have tried to read an empty analogRead(2) and it still returns me the same values as if the sensor is pluged in. I assume that it is possible to be broken.
Thank you very much for the answer!!
Again, analogRead() has no meaning here. It's a digital output!
Also your sketch suggests it's on pin A0, not on A2 (which is the one analogRead(2) tries to read - do keep the A in place to save yourself a lot of confusion as a digitalRead(2) is pin 2).
So do make sure the pin as defined in the sketch and where the sensor is connected match. If you have a sensor without breakout board, you have to add a 4k7 pull-up resistor to the data line (so between the data line and the 5V).
