DHT22 nRF24 receiving 0 value
Hello
I'm working on a project to receive temperature values with the DHT22 and nRF24l01. My values are sending but the receiver just gives 0 values, it just says ;
Temperature: 0
These are my programs, can someone help?
transmitter:
#include "DHT.h"
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
#define DHTPIN 4
#define DHTTYPE DHT22
RF24 myRadio (9, 10);
byte addresses[][6] = {"0"};
const int led_pin = 6;
struct Package
  float temperature ;
  float humidity ;
} data;
DHT dht(DHTPIN, DHTTYPE);
    pinMode(led_pin, OUTPUT);
    dht.begin();
    myRadio.begin();
    myRadio.openWritingPipe(addresses[0]);
    myRadio.setDataRate(RF24_250KBPS);
    myRadio.setChannel(115);
  digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
  readSensor();
  Serial.println("humidity:");
  Serial.println(data.humidity);
  Serial.println("temperature:");
  Serial.println(data.temperature);
  myRadio.write(&data, sizeof(data));
  digitalWrite(led_pin, LOW);
void readSensor()
 data.humidity = dht.readHumidity();
 data.temperature = dht.readTemperature();
This is the transmitting program and now the receiver
#include <RF24.h>
struct package
  float temperature ;
  float humidity ;
}data;
  Serial.print("Temperatuur:");
  myRadio.begin();
  myRadio.openReadingPipe(1, addresses[0]);      //open reading pipe 0 at address 00001      //Set RF output to minimum
  myRadio.setDataRate(RF24_250KBPS);       //set datarate to 250kbps
  myRadio.setChannel(115);                 //set frequency to channel 100
  myRadio.startListening();
checkForWirelessData();
void checkForWirelessData()
  if ( myRadio.available())
    while (myRadio.available())
    myRadio.read(&data, sizeof(data));
Just to clarify: You don't mention any Arduino hardware so both, sender and receiver, are Arduino UNOs. Correct?
The receiver is an UNO and the transmitter is an NANO
This is not a valid address. The code will read over the strings end and get random data so the two will not communicate with each other.
