DHT22 Refrigerator "range", with code, need help!
Hi all, I'm having an issue with my refrigerator I've made with Arduino. Basically it does work perfectly but I would like to add a "delay" to one of its functions. The RELAY1 (see code) does work when Temp is 25* and it's ok, but as soon as it goes down to 24 the refrigerator stop. It is actually doing what the code says but I want it this way:
temp goes 25 - refr. on - temp goes down to max 20 deg - refr. off - temp goes up again to 25 in a couple of hour - repeat
what should I change in my code?
note: all the other function must work while the first one is still "delaying" itself
 if(t >= 25)
    digitalWrite(RELAY1, LOW);}
    digitalWrite(RELAY1, HIGH); }
    static boolean running = false;
    if(t >=  25 && running == false)
        running = true;
    else if(t <= 20 && running == true)
        running = false;
Does this code help?
I’ll try ands let you know in a couple of hours
EDIT: It works! Thank you very very much!
groundfungus: Does this code help?
Kinda scary, that your code was a complex idea.
Chuck.
chucktodd: Kinda scary, that your code was a complex idea.
Chuck.
what do you mean?
