dht22 send "nan" data
Hi. I trying send dht22 data to mysql base in specific time with ds3231. But it always send 'nan' data. When i send data only with dht22, it works fine, but not with ds3231. What's the problem?
#include <SPI.h>
#include <Ethernet.h>
#include "DHT.h"
#define DHTPIN 7
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
#include <TimeLib.h>
#include <TimeAlarms.h>
#include <Wire.h>
#include <DS1307RTC.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Newer Ethernet shields have a MAC address printed on a sticker on the shield
IPAddress server(192, 168, 7, 1); //IPv4 address
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
IPAddress myDns(192, 168, 0, 1);
EthernetClient client;
  // wait for Arduino Serial Monitor
  while (!Serial) ;
  // get and set the time from the RTC
  setSyncProvider(RTC.get);
  if (timeStatus() != timeSet)
    Serial.println("Unable to sync with the RTC");
    Serial.println("RTC has set the system time");
  Alarm.alarmRepeat(10, 30, 0, Morningalarm);
  Ethernet.begin(mac);
  dht.begin();
  digitalClockDisplay();
  // wait one second between each clock display in serial monitor
  Alarm.delay(1000);
int idSensor = 1;
float hum = dht.readHumidity(); //Reading the humidity and storing in hum
float temp = dht.readTemperature(); //Reading the temperature as Celsius and storing in temp
float fah = dht.readTemperature(true); //reading the temperature in Fahrenheit
float heat_index = dht.computeHeatIndex(fah, hum); //Reading the heat index in Fahrenheit
float heat_indexC = dht.convertFtoC(heat_index); //Converting the heat index in Celsius
void Morningalarm() {
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.print("GET /data.php?");
    client.print("temperature=");
    client.print(temp);
    client.print("&humidity=");
    client.print(hum);
    client.print("&heat_index=");
    client.print(heat_indexC);
    client.print("&idSensor=");
    client.print(idSensor);
    client.println(" HTTP/1.1");
    client.println("Host: 192.168.7.1");
    client.println("Connection: close");
    client.println();
    client.stop(); //Closing the connection
    //if you didn't get a connection to the server:
    Serial.println("connection failed");
void digitalClockDisplay() {
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits) {
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
  Serial.print(digits);
