Dht22 sensor readings always zero
Hi!
I'm facing an issue with my code where the output (temperature and humidity) consistently remains at zero. Here's my code:
  • Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
  • Copyright (c) 2018 Terry Moore, MCCI
  • Permission is hereby granted, free of charge, to anyone
  • obtaining a copy of this document and accompanying files,
  • to do whatever they want with them without any restriction,
  • including, but not limited to, copying, modification and redistribution.
  • NO WARRANTY OF ANY KIND IS PROVIDED.
  • This example sends a valid LoRaWAN packet with payload "Hello,
  • world!", using frequency and encryption settings matching those of
  • the The Things Network. It's pre-configured for the Adafruit
  • Feather M0 LoRa.
  • This uses OTAA (Over-the-air activation), where where a DevEUI and
  • application key is configured, which are used in an over-the-air
  • activation procedure where a DevAddr and session keys are
  • assigned/generated for use with all further communication.
  • Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
  • g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
  • violated by this sketch when left running for longer)!
  • To use this sketch, first register your application and device with
  • the things network, to set or generate an AppEUI, DevEUI and AppKey.
  • Multiple devices can use the same AppEUI, but each device has its own
  • DevEUI and AppKey.
  • Do not forget to define the radio type correctly in
  • arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <DHT.h>
#include <DHT_U.h>
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]= { 0x34, 0x34, 0x34, 0x12, 0x12, 0x12, 0x12, 0x12 };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]= { 0xF0, 0x21, 0x00, 0xD8, 0x7E, 0xD5, 0xB3, 0x70 };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from the TTN console can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = { 0x01, 0x7F, 0x12, 0x8B, 0xC8, 0x32, 0x73, 0x2D, 0x0F, 0xFC, 0x38, 0x0C, 0x98, 0x8B, 0xD4, 0x0D };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = "Hello, world!";
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 20;
// Pin mapping
//# error "Unknown target"
const lmic_pinmap lmic_pins = {
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {3,4,5},
.rxtx_rx_active = 0,
.rssi_cal = 0, // LBT cal for in dB
.spi_freq = 1000000
#define DHT_PIN 7
#define DHTTYPE DHT22
DHT dht(DHT_PIN, DHTTYPE);
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
case EV_JOINING:
Serial.println(F("EV_JOINING"));
case EV_JOINED:
Serial.println(F("EV_JOINED"));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for (int i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print("-");
Serial.print(artKey[i], HEX);
Serial.println("");
Serial.print("nwkKey: ");
for (int i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print("-");
Serial.print(nwkKey[i], HEX);
Serial.println("");
// Disable link check validation (automatically enabled
// during join, but because slow data rates change max TX
// size, we don't use it in this example.
LMIC_setLinkCheckMode(0);
|| This event is defined but not used in the code. No
|| point in wasting codespace on it.
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if (LMIC.dataLen) {
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
Serial.println(F(" bytes of payload"));
Serial.print("Port: ");
Serial.println(LMIC.frame[(LMIC.dataBeg-1)]);
Serial.print("Data: ");
// char rec_data = (LMIC.frame + LMIC.dataBeg);
for (int i=0; i< LMIC.dataLen; ++i) {
if (i != 0)
Serial.print(",");
Serial.print(LMIC.frame[LMIC.dataBeg+i], HEX);
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
case EV_RESET:
Serial.println(F("EV_RESET"));
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
Serial.println(F("EV_TXSTART"));
default:
Serial.print(F("Unknown event: "));
Serial.println((unsigned) ev);
void do_send(osjob_t* j){
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
uint32_t humidity = dht.readHumidity(false)*100;
uint32_t temperature = dht.readTemperature(false) * 100;
    Serial.println("Humidity: " + String(humidity));
    Serial.println("Temperature: " + String(temperature));
    byte payload[4];
    payload[0] = highByte(humidity);
    payload[1] = lowByte(humidity);
    payload[2] = highByte(temperature);
    payload[3] = lowByte(temperature);
    // Prepare upstream data transmission at the next possible time.
    LMIC_setTxData2(3, (xref2u1_t)(payload), sizeof(payload), 0);
    Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
delay(5000);
while (! Serial)
Serial.println(F("Starting"));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);
LMIC_setDrTxpow(DR_SF7,14);
// Start job (sending automatically starts OTAA too)
do_send(&sendjob);
os_runloop_once();
Despite several attempts, I can't figure out why the output stays zero. Any insights or suggestions on debugging this would be great.
Thanks! :slight_smile:
In addition, can we ask for the format of the payload as well?
Please post your code using code tags <code>
 * Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
 * Copyright (c) 2018 Terry Moore, MCCI
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network. It's pre-configured for the Adafruit
 * Feather M0 LoRa.
 * This uses OTAA (Over-the-air activation), where where a DevEUI and
 * application key is configured, which are used in an over-the-air
 * activation procedure where a DevAddr and session keys are
 * assigned/generated for use with all further communication.
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate an AppEUI, DevEUI and AppKey.
 * Multiple devices can use the same AppEUI, but each device has its own
 * DevEUI and AppKey.
 * Do not forget to define the radio type correctly in
 * arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
#include <lmic.h>
#include <SPI.h>
#include <DHT.h>
#include <DHT_U.h>
// 0x70.
// Pin mapping
    .nss = 10,
    .rst = 9,
    .dio = {3,4,5},
    .spi_freq = 1000000
#define DHT_PIN 7
    Serial.print(": ");
    switch(ev) {
        case EV_JOINING:
        case EV_JOINED:
              u4_t netid = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
                if (i != 0)
                  Serial.print("-");
              Serial.println("");
                      if (i != 0)
                              Serial.print("-");
              Serial.println("");
        || case EV_RFU1:
        ||     break;
        case EV_TXCOMPLETE:
            if (LMIC.dataLen) {
                if (i != 0)
                  Serial.print(",");
        case EV_LOST_TSYNC:
        case EV_RESET:
        case EV_RXCOMPLETE:
        case EV_LINK_DEAD:
        case EV_LINK_ALIVE:
        || case EV_SCAN_FOUND:
        ||    break;
        case EV_TXSTART:
        default:
        byte payload[4];
    delay(5000);
    while (! Serial)
    #ifdef VCC_ENABLE
    #endif
    // LMIC init
    os_init();
    LMIC_reset();
    do_send(&sendjob);
    os_runloop_once();
here's the formatter code i used in ttn
 function Decoder(bytes, port) {
    var decoded = {};
    if (port === 1) {
        decoded.message = String.fromCharCode.apply(null, bytes);
    else if (port === 3) {
        var data = bytes;
        decoded.hum = (data[0] << 8 | data[1])/100;
        decoded.temp = (data[2] << 8 | data[3])/100;
    // Return decoded object
    return decoded;
