I'm using an breadboard Attiny85 & software serial to experiment with a DHT22 temp and humidity sensor with a 10k resistor between pin 1 Vcc(5v) and pin 2 data, with pin 4 tied to GND (I've also tried it with pin 3 also tied to GND). I'm using the adafruit DHT library, and the following code.
#include "SoftwareSerial.h"
#include "DHT.h"
#define DHT22PIN 0 //DHT is on pin 0 (pinout 5)
#define DHTTYPE DHT22
DHT dht(DHT22PIN,DHTTYPE); // pin 0 (pinout 5) DHT22
SoftwareSerial TinySerial(3, 4); // RX, TX pinout g2,y3
// Open serial communications and let us know we are connected
TinySerial.begin(9600);
TinySerial.println("Tiny Serial Connected via SoftwareSerial Library");
dht.begin();
delay(1000); //delay so I can give myself time to think
float h = dht.readHumidity();
float t = dht.readTemperature();
delay(250); //delay to give sensor time to read
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
TinySerial.print("\n");
TinySerial.print("Received data...");
TinySerial.print("Humidity: ");
TinySerial.print(h);
TinySerial.println(" %\t");
TinySerial.print("Temperature: ");
TinySerial.print(t);
TinySerial.println(" *C");
TinySerial.println("Next reading in 5 seconds");
delay(5000);
The output I'm receiving on the serial monitor is as follows:
Received data...
Humidity: 32.80 %
Temperature: 0.40 *C
Next reading in 5 secondsReceived data...
Humidity: 40.20 %
Temperature: 0.80 *C
Humidity: 33.60 %
Humidity: 16.00 %
Temperature: 12.80 *C
Occasionally, the humidity or the temperature will be in the expected ranges. I've tried using different pins for the inputs and outputs and get the same response. Similar code worked for a DHT11, but my requirements for temp are below 0 celsius. Any hints on what might be my issue? Thanks in advance for any possible help.
