DHT22 Temperature Controlled Fans RPM
Hello all!
I am an electrical engineering student relatively new to arduinos working on an automated green house tech project.
To the point:
I have built a simple "on/off control" (heater on when too cold, fans on when too hot) but would like to have smarter control over 2-3 fans constantly running and being RPM controlled, speeding up when increasingly hot and slowing down/shutting off if temperature dips. My sensor is a DHT22 temperature/humidity sensor and I have 4 wire fans PWM control at my disposal.
Looking at some advice or links on how to do this!
You will probably need too know more about the characteristics of the fan motors.
If they are dc motors, you control the speed by the effective voltage using pwm.
If they run off a/c, this won't work. You can research how variable speed ceiling fans work.
Variable speed fans in computers now are often brushless motors with variable frequency drives.
It may be simpler to just turn them on and off, than changing the speed.
Or, if you have 2 or 3 fans, turning 1 or more of them off.
michinyon:
I have 3, 4-wire computer fans that are 12VDC. I have a separate 12V supply powering the fan and it was my understanding that I send the PWM pulse through the 4th wire to change the speed of the fan. When everything is hooked up the fan starts up and stays a constant speed. I have been unable to change the speed of the fan.
I have been able to use the sample LED fade to ensure that my PWM is working but sending a PWM signal to the fan doesn't seem to do anything.
These are the fans I'm using:
http://www.deepcool.com/product/dcoolingaccessory/2013-12/12_639.shtml
try this
temp = dht22.getTemperature();
speedFan1 = map(temp, 18, 30, 0, 255);
analogWrite(FAN1, constrain(speedFan1 , 0, 255) );
speedFan2 = map(temp, 10, 30, 0, 255);
analogWrite(FAN2, constrain(speedFan2 , 0, 255));
etc
I have figured it out! My fans do not need a transistor on the PWM pulse and can be directly connected.
For any future searchers I used this:
   pinMode(3, OUTPUT);
   TCCR2A = 0x23;
   TCCR2B = 0x09;  // select clock
   OCR2A = 79;     // aiming for 25kHz
   OCR2B = 62;     // set the PWM duty cycle
void loop(){
    analogWrite(3, HIGH);   //sends PWM signal
    OCR2B = 0;                 // min fan speed
   delay(5000)
    OCR2B = 79;               // max fan speed
   delay(5000);
It sets the frequency of the PWM signal and then turns the fan from minimum speed to maximum every 5 seconds. You use the OCR2B value to control the speed of the fans.
Detailed explanation here:
http://forum.arduino.cc/index.php?topic=18742.0t
Also if anyone is doing a mini greenhouse project like me, here is the start of my program (be nice, it's a work in progress):
#include "DHT.h"           // include dht sensor library
#define DHTPIN 2           // temp/hum sensor pin
#define DHTTYPE DHT22      // type of DHTxx sensor = DHT 22  (AM2302)
#define fan 4              // fan on-off pin (relay)
#define fanPWM 3           // fanPWM speed control signal pin
#define heater 5           // heater pin
int setHum = 55;       // humidity setpoint % 0-100
int setTemp = 15;      // temperature setpoint degrees Celsius
int minHum = 50;       // humidity MIN % 0-100
int maxHum = 70;       // humidity MAX % 0-100
int minTemp = 10;      // temperature MIN degrees Celsius
int maxTemp = 30;      // temperature MAX degrees Celsius
DHT dht(DHTPIN, DHTTYPE);      // Initialize DHT sensor for normal 16mhz Arduino
  Serial.begin(9600);           // enable serial monitor
  pinMode(fan, OUTPUT);         // enable fan output
  pinMode(fanPWM, OUTPUT);      // enable fanPWM signal output
  pinMode(heater, OUTPUT);      // enable heater output
  dht.begin();                  // begin dht sensor library
////////////////////Fan Speed 25KHz Clock Speed Setup////////////////////
   TCCR2A = 0x23;  // set time clock multiplier
   OCR2B = 30;     // set the PWM duty cycle
  ////////////////////Temp/Hum Sensor Readings////////////////////
   delay(2000);        // Wait a few seconds between measurements.
   float h = dht.readHumidity();           // read humidity
   float t = dht.readTemperature();        // read temperature as Celsius
   float f = dht.readTemperature(true);    // read temperature as Fahrenheit
    if (isnan(h) || isnan(t)) {             // Check if any reads failed and exit early (to try again)
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    float hi = dht.computeHeatIndex(f, h);  // compute heat index (temp must be sent in fahrenheit)
    Serial.print("Fan Speed: ");        // print fanSpeed readings to serial
    Serial.print(OCR2B);
    Serial.print("\t Humidity: ");      // print temp/hum readings to serial
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.print(" *C ");
    Serial.print(f);
    Serial.print(" *F\t");
    Serial.print("\t Heat index: ");
    Serial.print(hi);
    Serial.println(" *F");
     if(t < minTemp) {    // if temperature falls below minTemp or minHum - turn fans OFF
        digitalWrite(fan, LOW);
        analogWrite(fanPWM, LOW);
        digitalWrite(heater, HIGH);
        OCR2B = 0;                      // speed of fan to 0
     else{                              // keep minimum airflow
        digitalWrite(fan, HIGH);
        analogWrite(fanPWM, HIGH);
        digitalWrite(heater, LOW);
  ////////////////////Fan Logic////////////////////
     if(h >= minHum || t >= minTemp)   // speed level 1
       OCR2B = 20;                     // fan = minimum
     if(t >= setTemp)             // speed level 2
        OCR2B = 30;               // fan + 10
     if(t >= setTemp + 5)         // speed level 3
        OCR2B = 40;               // fan + 20
     if(t >= setTemp + 10)        // speed level 4
        OCR2B = 50;               // fan + 30
     if(t >= setTemp + 15)        // speed level 5
        OCR2B = 60;               // fan + 40
     if(h >= maxHum || t >= maxTemp)    // speed level maximum
        OCR2B = 79;                     // fan = maximum
Cheers!!!
