hi, trying hard to get a DHT22 working (using direct 5v PSU & 5.1k resistor between V & signal) with ESP8266-12 (on GPIO14), using the Rob Tillaart sketch (from dht.h - version: 0.1.13 library):
// FILE: dht22_test.ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.03
// PURPOSE: DHT library test sketch for DHT22 && Arduino
// URL:
// HISTORY:
// 0.1.03 extended stats for all errors
// 0.1.02 added counters for error-regression testing.
// 0.1.01
// 0.1.00 initial version
// Released to the public domain
#include <dht.h>
dht DHT;
#define DHT22_PIN 5
struct
uint32_t total;
uint32_t ok;
uint32_t crc_error;
uint32_t time_out;
uint32_t connect;
uint32_t ack_l;
uint32_t ack_h;
uint32_t unknown;
} stat = { 0,0,0,0,0,0,0,0};
Serial.println("dht22_test.ino");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT_LIB_VERSION);
Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)\tTime (us)");
// READ DATA
Serial.print("DHT22, \t");
uint32_t start = micros();
int chk = DHT.read22(DHT22_PIN);
uint32_t stop = micros();
stat.total++;
switch (chk)
case DHTLIB_OK:
stat.ok++;
Serial.print("OK,\t");
case DHTLIB_ERROR_CHECKSUM:
stat.crc_error++;
Serial.print("Checksum error,\t");
case DHTLIB_ERROR_TIMEOUT:
stat.time_out++;
Serial.print("Time out error,\t");
case DHTLIB_ERROR_CONNECT:
stat.connect++;
Serial.print("Connect error,\t");
case DHTLIB_ERROR_ACK_L:
stat.ack_l++;
Serial.print("Ack Low error,\t");
case DHTLIB_ERROR_ACK_H:
stat.ack_h++;
Serial.print("Ack High error,\t");
default:
stat.unknown++;
Serial.print("Unknown error,\t");
// DISPLAY DATA
Serial.print(DHT.humidity, 1);
Serial.print(",\t");
Serial.print(DHT.temperature, 1);
Serial.print(stop - start);
if (stat.total % 20 == 0)
Serial.println("\nTOT\tOK\tCRC\tTO\tUNK");
Serial.print(stat.total);
Serial.print("\t");
Serial.print(stat.ok);
Serial.print("\t");
Serial.print(stat.crc_error);
Serial.print("\t");
Serial.print(stat.time_out);
Serial.print("\t");
Serial.print(stat.connect);
Serial.print("\t");
Serial.print(stat.ack_l);
Serial.print("\t");
Serial.print(stat.ack_h);
Serial.print("\t");
Serial.print(stat.unknown);
Serial.println("\n");
delay(2000);
// END OF FILE
i'm getting this serial output error:
DHT22, Time out error, -999.0, -999.0, 2306
DHT22, Time out error, -999.0, -999.0, 2309
DHT22, Time out error, -999.0, -999.0, 2305
etcetera...
using this board manager version:
https://github.com/esp8266/Arduino & http://arduino.esp8266.com/versions/1.6.5-947-g39819f0/doc/reference.html
using Arduino 1.6.4 IDE
can anyone assist?
thanks!
