I have the dht22 wired sensor from adafruit conected to digital pin 2. I haven't played with arduino in over a year so any help or guidance from a couple things:
1:
I'm using this sensor so I can activate a relay going to a crock pot. This is where it'll turn on or off at a certain temperature.
2:
I'm using the humidty part to know when I need to open a valve controlled by a servo to control the humidty at a certain percentage.
3:
I have got it working on a LCD 16x2 display temp (f) and humidty. This will be just an extra add on and later I made add a min/max feature.
Also out of question (may need to be in hardware) has any interfaced this small relay off eBay that's already on a pcb?
Can hardly see the pinout on silkscreen (I bought one).
Check - Arduino Playground - DHTLib - it supports a DHT22
Make the switchON and switchOFF temperatures two variables, to get some degree of freedom and to prevent fast ON/OFF iterations. Same for humidity
Here a sketch to get started, Temperature is almost coded, DHT.humidity is left as an exercise
just as some other parts...
Succes,
Rob
(not compiled or tested)
#include <dht.h>
dht DHT;
#define DHT22_PIN 2
#define CROCKPOTPIN 8
#define TEMP_HIGH 22
#define TEMP_LOW 20
#define HUMID_HIGH 60
#define HUMID_LOW 20
float minTemp = 100;
float maxTemp = 0;
float minHumid = 100;
float maxHumid = 0;
int crockValue = 0;
Serial.println("TEST PROGRAM ");
pinMode(CROCKPOTPIN, OUTPUT);
// READ DATA
int chk = DHT.read22(DHT22_PIN);
// DO THE MIN/MAX
minTemp = min(minTemp, DHT.temperature);
maxTemp = max(maxTemp , DHT.temperature);
// DISPLAT DATA
Serial.println(DHT.temperature, 1);
// CROCKPOT
if (DHT.temperature > TEMP_HIGH) crockValue = 1;
else if (DHT.temperature < TEMP_LOW) crockValue = 0;
digitalWrite(CROCKPOTPIN, crockValue);
delay(2000); // DHT's need a delay between readings ...
Didn't compile correctly... But this does:
#include "DHT.h"
#define DHTTYPE DHT22
#define DHTPIN 2
DHT dht(DHTPIN, DHTTYPE);
#define CROCKPOTPIN 4
#define TEMP_LOW 20
float maxTemp = 0;
float maxHumid = 0;
int crockValue = 0;
// READ DATA
int t = dht.readTemperature();
int temperatureF = (t * 9 / 5) +32.5;
// DO THE MIN/MAX
minTemp = min(minTemp, t);
maxTemp = max(maxTemp , t);
// DISPLAT DATA
Serial.println(temperatureF);
// CROCKPOT
if (t > TEMP_HIGH) crockValue = 1;
else if (t < TEMP_LOW) crockValue = 0;
OK!,
If you work in Fahrenheit you might need to initialize the minTemp also in Fahrenheit : 212 iso 100 ![]()
How so? I believe standard the library is in Celcius not fahrenheit which I had to calculate to display F
Edit:
Basically the relay which is connected to say pin 4 its HIGH (relay closed) crock pot will be on till about 120ish degrees F. If it goes higher than 120 then the relay will be LOW (relay open).
OK you do the internal math in Celsius and display it ion Fahrenheit. That makes my remark obsolete. I was under the assumption that you would do the math in F My mistake.
If it is only for the displaying part you could move these lines together, combine them in a logical block or better a separate function. That would make it more explicit that only for displaying F is used ..
void displayTemp(int C)
int F = (C * 9 / 5) +32;
Serial.println(F);
I was meaning by reading the value of c (hence it's in celcius when on or off). Couldn't I use #define 120 in f not in c by using some math or am I just going to have to calculate it only for displaying ane figure the temp I'd have to set at in c for the relay?
You could do the whole sketch in Fahrenheit except the sensorreading. But even for that you could do
int f = (sensor.getTemperature() * 9 / 5) + 32;
#define 120 ==> #define ((120 * 9 /5) + 32) ![]()
