Did attatchInterrupt() change in 1.0?
Hi All…
For the past few hours I have been trying to get an Arduino 022 sketch to work. All of it works except, apparently, the attatchInterrupt() call. The I2c stuff woks fine. The code should catch a hardware interrupt and execute the ISR. It does not on Arduino 22. However, it works perfectly on 1.0.
Here is the code…
Thanks very much.
#include <I2C.h>
#define NXP_UART  0x4D
#define REG_SPR0 0x38 /* Stoarage register UART 0 */
#define REG_SPR1 0x3A /* Stoarage register UART 1 */
#define REG_IIR 0x10
#define REG_IOCTL 0x70
#define REG_IODIR 0x50
#define REG_INTENA 0x60
#define REG_IOSTATE 0x58
#define INT_PIN 2
const unsigned char LED_DATA = 20;   // Physical pin 23
const unsigned char LED_ERROR = 21; // Physical pin 24
const unsigned char LED_INFO = 22;  // Physical pin 25
const unsigned char L_LED = 7;      // Physical pin 3
volatile int state = LOW;
volatile unsigned char iir;
  Serial.println("Writing to SPR...");
  // Set up LED for output
  pinMode(LED_ERROR, OUTPUT);
  I2c.begin();
  I2c.setSpeed(1);
  uint8_t buf[2];
  buf[1] = NULL;
  I2c.write(NXP_UART, REG_SPR1, 0xAA);
  I2c.read(NXP_UART, REG_SPR1, 1, buf);
  Serial.print("Read from SPR: ");
  Serial.println(buf[0], HEX);
  Serial.println("Set IO Control - All GPIO pins as IO with latch on");
  I2c.begin();
  I2c.write(NXP_UART, REG_IOCTL, 0x01);
  Serial.println("Set IO Direction - All GPIO pins as input");
  I2c.write(NXP_UART, REG_IODIR, 0x00);
  Serial.println("Set IO Int Enable - All GPIO pins generate int");
  I2c.write(NXP_UART, REG_INTENA, 0xFF);
  // Attatch interrupt handler
  attachInterrupt(INT_PIN, stateChange, CHANGE);
  Serial.print("IIR: ");
  Serial.println(iir, HEX);
  delay(250);
void stateChange()
  state = !state;
  digitalWrite(LED_ERROR, state);
  uint8_t buf[2];
  // Read IIR to see what caused the interrupt
  I2c.read(NXP_UART, REG_IIR, 1, buf);
  // Clear interrupt condition
  I2c.read(NXP_UART, REG_IOSTATE, 1, buf);
  iir = buf[0];
Is that a problem? What is it you need help with?
PaulS:
I have not ported my code to 1.0 yet, its still on 22. So I guess the time has come. The only library I am using that I don't have a 1.0 version of yet is SdFat, and I think he did port it. Couldn't find it though. I posted that over in storage.
but
OK.
I have a feeling that the first parameter to attachInterrupt() should be 0 or 1 you seem to be using 2
pin 2 is interrupt 0 pin 3 is interrupt 1
I theenk
PS 2 is pin 21 on a Mega 3 is pin 20 on a Mega 4 is pin 19 on a Mega 5 is pin 18 on a Mega
Paul, cut me a little slack here. The test code ran perfectly. Its not even a page. The entire app is about 40 files and none of them are very short. Porting to a new environment is easier said than done.
mmcp42: I have a feeling that the first parameter to attachInterrupt() should be 0 or 1 you seem to be using 2
I theenk
Ah yes, thank you very much! I can hack the core to fix that little issue.
Probably I'll just port my code instead.
