so i got board last night and i connected a bunch of wires to a battrey thing on like a tv remote on the back and when i did i smelt burning once i unpluged it all my arduino uno wont let code upload on to it and only the gnd and v5/v3.3 works
every electronic component has smoke inside.
If the smoke comes out it stops working......
The fix is relative easy, use the existing one to connect wires etc to where you do not know what you are doing and purchase a new one that you want to work. Electronics is like glass, break it and it does not go back together.
no smoke came out
maybe you haven't seen it but
if you smelled burning it is because smoke came out.
Okay, I'll bite. What is that? It sounds like you don't even know what it is. Maybe we can help you identify it if you provide a photo or link.
Based on what you posted, I guess you didn't read what you were asked to read when you joined. Now would be a good time.
battey pack
I see that you do not follow instructions. Had you read either my reply, or the document you were asked to read, you would not be posting an unhelpful two word answer.
the back of a remote that you put batteys in
I'm blocking you permanently because you are not following the forum instructions, or hints to do so. Good luck.
For clarification @anon57585045 has added you to his/her personal ignore list rather than blocking your access to the forum
Oh right, sorry... I will make that more explicit next time. "putting you on my ignore list..."
Thanks
