@tadashimori
Lets see here. The LED determines the voltage drop, not you. You're probably calculating it in the wrong way.
If you use a LED that draws 2.2v, that's the voltage drop across it, not 2.4 or 2.6.
In your example you used 5v, with the 2.2 voltage drop of the LED, the resistor will drop 2.8v
Now, as you have determined the voltage drop across the resistor, you determine how much current you want to pass on the led.
Suppose you want to pass 0.01A, so, now you calculate with U=R.I
U = 2.8 (voltage drop across the resistor)
I = 0.01 A
So, you have R = 280 ohms, and it will draw 0.01A no matter what's the current limit of your source, as long as it's 5v.
When discussing leds, you don't talk about a "voltage drop across the led".
Leds are NONLINEAR.
It is NOT a voltage drop per se , it a FORWARD VOLTAGE (Vf) , found on a datasheet.
"Voltage drop across ..." is an Ohm's Law expression used to describe LINEAR resistance, NOT
NON-LINEAR FORWARD VOLTAGE.
Technically , yes the voltage is "dropped" across the led but it is not described that way.
One would say "the forward voltage for the led is ____"
When you start talking about "voltage drop across" any newbie is going to think they can apply Ohm's
Law to a led. "
If they then see the schematic with 9V and a 330 ohm resistor going to a 2.4V led, they might think
"Well, let's see, the resistor has (9V-2.4V) = 6.6V across it so it is drawing 20mA , and the led has
2.4V across it and is drawing 20mA, so it must have a resistance of 2.4V/0.02A = 120 ohms.
But when they try to measure the led resistance they are not going to see 120 ohms because it is
NONLINEAR.
This is why we try to avoid using the term "voltage drop across" when discussing leds. Instead we say
"the led forward voltage is 2.4V".
Ok, if we're trying to learn (or teach) electronics, we need to get our nomenclature correct.
The above statement is incorrect because you don't say a led "draws 2.2V", if you WERE going to say
something like that you would say a led "DROPS 2.2V" and even this is really not the correct way to
state this information.
The correct way to state this is :
"If a led has a forward voltage drop (Vf) of 2.2V..."
"draws .." is a term used to refer to CURRENT , NOT VOLTAGE.
When referring to voltage, one would say "DROPS" (NOT "DRAWS")
(If you're going to try to be a forum electronics consultant, at LEAST learn to "talk the talk".)
