Hi, I need some advice on the right choice of all the components for my project. I have a 3D printer at home on which I want to print a design for such a universal engineering harness. Inspired by the game from the "Fallout" series, in which the player wears a pacifier named "Pip-Boy". In this post-apocalyptic genre game, this device is fully analog due to its high resistance to the electromagnetic pulse of an atomic bomb explosion, adverse climatic conditions, including radioactive fallout or also due to resistance to rough handling.
The device should have an analog operating interface with a small monitor and the simplest possible graphic interface, also an analog radio and the ability to use a mobile GSM band, WI-FI, Bluetooth, GPS, compass, gyrocompass, Geiger counter, temperature and other sensors (the more the better =D), speaker and microphone, USB inputs and outputs, flashlight, primary power supply from rechargeable batteries and back-up power supply from a magazine for AA batteries and a second magazine for AAA batteries. An advantage would also be a simple wire that could be attached anywhere and to any contact through which a weak current passes, but for the time being I have not come up with any reasonable solution that could be used to universally regulate any voltage in a low range without having to pull on my hands ""ten kilo coil"". =D A heart rate and blood pressure sensor would also be an absolute gem. In addition, I have a device designed to be waterproof to a great depth, in short, such a helper for discomfort, but also a tool for electrical engineering operations of all kinds from A to Z, or even a helper in theoretical and experimental research of unexplained phenomena in nature and in the laboratory.
I design my equipment in 3D Design (Autodesk Fusion-360). The design is completely different from what is shown in the game "Fallout", because the design created by "Bethesda" for the game "Fallout" is completely without sophisticated features. The capabilities of the device that I describe above will certainly fit into this power supply, but I would like to know the opinion of the Arduino community if I have chosen the right components. When choosing, emphasis should be placed primarily on analog properties, preferably if everything is analog. My design solution guarantees high resistance in addition to magnetic field and electromagnetic interference, which I hope should be solved at least in part by analog components, so I mainly focus on the sensor interface and close connectivity with the components.
I chose these components:
Board
- MKR GSM 1400
Shields
- MKR MEM
- MKR ENV
- MKR GPS
- MKR RGB
- MKR 485
- MKR IMU
So the questions are:
- Is this combination of components satisfactory?
- Will it be enough to connect other devices, (Geiger counter, walkie-talkie, monitor, heart rate sensor, etc...)? And would it be possible at all, or will I have to adapt these devices to work independently without connecting to the interface?
- What is your opinion on it, or rather what components would you choose in my place? =)
I wish everyone a nice rest of the day, and may all the other days be nice too, forever. =D
ShadyDowns - Theoretical and experimental scientist
