Hi all, I think I messed um my Arduino. Actually I don't know how. I used it as an signaloutput for a boost converter for Nixie tubes. It gave this signal to the base of a transistor. But I had only a 16R resistor infront of the transistor. The boost converter worked fine. Could this be the reason for the damage at my Arduino?
The LED at the pin #13 is shining really dark if pin 13 is high.
I have uploaded some code to test the pins with an oscilloscope:
void setup (){} void loop() { digitalWrite(13,HIGH); delayMicroseconds(100); digitalWrite(13,LOW); delayMicroseconds(100); digitalWrite(12,HIGH); delayMicroseconds(100); digitalWrite(12,LOW); delayMicroseconds(100); }
Scope settings: Both channels .2V/div .1ms/div I am using a 1:10 divider.
The voltage of pin 13 is lower tham the voltage of pin 12. Both signals are messed up.
I have tested three different microcontrollers. Always the same problem, so I think the microcontroller is OK.
What could be broken?
I hope somebody can help.
Greets MrMcChicken
