First of all, I'm a beginner with Arduino and this is my first post, so hello everybody
I've a question about the following code.
It work pretty well until millis() reaches 65535, then a call to aBtn.read() always return 1 since millis() reaches 131071.
It smell like a uint16 overflow but I can't definitely find where it comes from
Does anybody has a clue ?
Regards,
Damien
// SimpleButton.h
#ifndef SimpleButton_h
#define SimpleButton_h
#include <stdlib.h>
#include <stdio.h>
#include <stdint.h>
#include <WProgram.h>
class SimpleButton {
private:
 unsigned long lastReadTime;
 uint8_t lastReadValue, pin, temp;
public:
 SimpleButton(uint8_t);
 uint8_t read();
#endif
// SimpleButton.cpp
#include "SimpleButton.h"
#include <stdlib.h>
#include <stdio.h>
#include <stdint.h>
#include <wiring.h>
SimpleButton::SimpleButton(uint8_t btnPin) {
 pin = btnPin;
uint8_t SimpleButton::read() {
 if (millis() > (lastReadTime + 20)) {
  temp = digitalRead(pin);
  if (lastReadValue == 0 && temp == 1) {
   lastReadValue = 1;
   lastReadTime = millis();
   return 1;
  if (temp == 0) {
   lastReadValue = 0;
  return 0;
I can't see where the uint16 overflow happens, but shouldn't you have a return statement also in the top scope of the SimpleButton::read() function? Now it returns a defined value only when (millis() > (lastReadTime + 20)) is true.
That should be the issue. I'll test it tonight.
I suppose, correct me if I'm wrong, that the return value is read from a register and as the function doesn't set it, it's kinda random (or depending of the last function call return value) ?
I'm corrupted by the "Not all code returns a value" error in some IDEs
Yes it returns a random value, at least on the other compilers I have worked with. (What ever happens to be in the register that holds the return value).
Btw, if you what to be sure that the statement "(millis() > (lastReadTime + 20)) " works when millis() actually overflows in about 50 days, you may need to change it to: "(millis() - lastReadTime > 20) ".
