Now, did you know that you can unset the CKDIV8 at runtime? Not the fuse itself, but by modify CLKPR.
Apparently, all CKDIV8 does is determine the initial value loaded into CLKPR!
I agree with you completely. The Arduino system is "dumbed down" to allow people with limited programming experience to actually be able to write a working program, but IMHO they take it too far.
Stuff that "doesn't compile anymore" is usually due to changes in GCC rather than the IDE itself.
In my setup, I completely removed the whole "tools" directory that has the avr-gcc compiler code and compiled my own (version 4.9.2) instead. As long as the compiler, linker, etc... are in the executable path, it works properly.
If I use the IDE at all, it's just for the "upload" button. I edit code using nano and serial monitor using minicom.
I've got a nice universal Makefile that takes the directory name I'm working in and passes it to the Makefile as the project name (so all I need to do is type "build" in the sketch directory).
It's nice to combine it all into one command line such as "nano program.ino && build && minicom", then it does everything automatically. To go again, all I need to do is quite "minicom" and recall the last command line and do it again.
(and about 1000 tries later I may actually have a program that works! )
