Diecimila Beginner
Hi!
I've just bought my first Diecimila and I'm trying to do the basic led blinking sketch but I have the same message error:
hardware/tools/avr/bin/avr-gcc: line 2: readlink: command not found
hardware/tools/avr/bin/avr-g++: line 2: readlink: command not found
Any idea what it might be?
Thanks a lot, guys
Dario
Can you post your code up?
Hiya!
Thanks a lot for your reply!
the code is:
  • Blink
  • The basic Arduino example. Turns on an LED on for one second,
  • then off for one second, and so on... We use pin 13 because,
  • depending on your Arduino board, it has either a built-in LED
  • or a built-in resistor so that you need only an LED.
  • http://www.arduino.cc/en/Tutorial/Blink
int ledPin = 13; // LED connected to digital pin 13
void setup() // run once, when the sketch starts
pinMode(ledPin, OUTPUT); // sets the digital pin as output
void loop() // run over and over again
digitalWrite(ledPin, HIGH); // sets the LED on
delay(1000); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
Have you properly installed the board and selected which port it is located on?
What operating system are you using?
The code looks OK to me.
