diecimila without external power circuit
Hi, I purchased diecimila bare board and solderd all components except ckt which is related to external power supply as I want to run that board only from USB. Somehow sketch does is not starting. If I put same processor (ATMEG168) to board with complete circuit, it works fine. Is this expected? From schematics, as long as I am using jumper, external power supply circuit is independant of USB power source.
Is this expected?
No you must have something wrong with your construction of your setup.
What is a ckt?
Thanks for the reply. Aactually I am not having stock for MC3326D nor I need external power supply. So I want to use only USB power. I checked voltage levels at all points in my circuit and looks like clock is fading away. I do not have CRO to confirm this but for 2-3 seconds after I connect USB, I see some voltage across 16MHz Crystal but it soon fades away to zero level....
