Diferent compilator
The compilator os giving a lot of problems.
Someone know about a diferent compilator???
No.
Post the errors and we'll help you fix them.
Post:
Full text of any and all compile errors
The board that you are compiling for
The version of Arduino IDE, and board package you are using.
For most/all boards, there is no alternative toolchain available, certainly not one compatible with the rest of the system, so your only option is to fix the problem you are encountering with the compiler at hand. Since the rest of us use it with no issue, we know the compiler is fine in general, so something is wrong with either the code you are compiling, or your system/installation.
