So I would like to use a Arduino Leonardo to create a keyboard with some common complex terminal commands. I understand how I should do this project, but one issue i'm having trouble with is to detect if the command is comming from the Arduino or if a command comes from my usual keyboard.
When the Arduino Leonardo sends a keypres via the USB port. Is there any flag showing it comes from an Arduino? or are the keys sent exactly the same as from a regular keyboard?
I could look at what USB port the command is coming from. But then the Arduino needs to use the same port everytime so I rather not do this.
Yes, but not an easily detectable.
Yes, that's the intention. The keys are sent exactly as if the Arduino is a regular keyboard. From a technical point of view the Arduino is a regular keyboard.
This sounds as you would like to distinguish between the Arduino and a standard keyboard. Why would you like to do that?
