I'm trying to figure what is the difference in purpose, function, or application between figure 11 on page 6 and figure 12 on page 7.
The value of 1 Resistor and Capacitor, which I believe are a snubber, is the only difference that I see.
Which one of these should I use to turn on or off a over the counter electric space heater with fan. 120VAC 1500 w.
Don't "snub" their extensive app note which may have some answers.
Note that the 1500W space heater/fan would have a much higher resistive load component than inductive. I would think this R-L load would act as its own snubber.
Looked through the ap notes that were posted. Uhhh. Little too much info overload. I get that Triac is basically a switch for AC. Sometimes if you have too much noise on the line caused by a motor or some such thing you may get false triggering. Hence a snubber which is basically a filter. IS that about right?
Looking at the simple resistive load circuit example in the white papers I am surprised to see the only thing in between the full 120vac and the detector side of the optocoupler is only a 180 ohm resistor. Doesn't this mean the full 120VAC will be applied to the gate at times? This doesn't damage the triac?
Yes.
No - most of the 120VAC will be dropped across the resistor.
