Hello,
To keep things short, I have a problem with a FPGA sketch. Everything works as expected when i start the MKR 4000 board connected to a PC via a data USB cable, and if i disconnect it everything still works (the board is powered by 5V on the Vin pin).
If I start the board without connecting it to the PC things gets wierd. The FPGA design works more or less, but there is minor data corruption when I write data to the RAM, corruption which is not present when the board is booted with the data USB cable connected. I suspect that something isn't working quite right with the FPGA configuration when the USB cable is unplugged during startup.
I can of course go into more detail, but i think I'll keep it short for now.
Does anyone have an idea what might be happening? It seems like the only real difference between the cases is the presence of the USB DP and DM wires, so i guess something happens differently during startup depending on whether USB communication is up and running. I can't for the life of me figure out what that might be however.
Earlier tests:
I suspected the battery management IC capped the input current to 100 mA at first, which i thought might not be enough to configure the FPGA correctly, but it turns out that the board is capped at 100 mA even with the USB data cable attached. I tried changing the input current limit on the chip via I2C, but that made no difference neither.
I've tried a USB charge only cable hooked up to the PC, that didn't work so I'm fairly certain that having a USB host connected is the important part, instead of some magical ground problem.
Here is the sketch I'm using to configure the FPGA, I'm using the method provided by SmarkAleks back in the day
#include <arduino.h>
#include <SPI.h>
#include "jtag.h"
// For High level functions such as pinMode or digitalWrite, you have to use FPGA_xxx
// Low level functions (in jtag.c file) use other kind of #define (TDI,TDO,TCK,TMS) with different values
#define FPGA_TDI (26u)
#define FPGA_TDO (29u)
#define FPGA_TCK (27u)
#define FPGA_TMS (28u)
// Clock send by SAMD21 to the FPGA
#define FPGA_CLOCK (30u)
// SAMD21 to FPGA control signal (interrupt ?)
#define FPGA_MB_INT (31u)
// FPGA to SAMD21 control signal (interrupt ?)
#define FPGA_INT (33u) //B2 N2
// For MKR pinout assignments see : https://systemes-embarques.fr/wp/brochage-connecteur-mkr-vidor-4000/
extern void enableFpgaClock(void);
#define no_data 0xFF, 0xFF, 0xFF, 0xFF, \
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, \
0x00, 0x00, 0x00, 0x00 \
#define NO_BOOTLOADER no_data
#define NO_APP no_data
#define NO_USER_DATA no_data
__attribute__ ((used, section(".fpga_bitstream_signature")))
const unsigned char signatures[4096] = {
//#include "signature.ttf"
NO_BOOTLOADER,
0x00, 0x00, 0x08, 0x00,
0xA9, 0x6F, 0x1F, 0x00, // Don't care.
0x20, 0x77, 0x77, 0x77, 0x2e, 0x73, 0x79, 0x73, 0x74, 0x65, 0x6d, 0x65, 0x73, 0x2d, 0x65, 0x6d, 0x62, 0x61, 0x72, 0x71, 0x75, 0x65, 0x73, 0x2e, 0x66, 0x72, 0x20, 0x00, 0x00, 0xff, 0xf0, 0x0f,
0x01, 0x00, 0x00, 0x00,
0x01, 0x00, 0x00, 0x00, // Force
NO_USER_DATA,
__attribute__ ((used, section(".fpga_bitstream")))
const unsigned char bitstream[] = {
#include "app.h"
// the setup function runs once when you press reset or power the board
int ret;
uint32_t ptr[1];
enableFpgaClock();
//Init Jtag Port
ret = jtagInit();
mbPinSet();
// Load FPGA user configuration
ptr[0] = 0 | 3;
mbEveSend(ptr, 1);
// Give it delay
// Configure onboard LED Pin as output
pinMode(LED_BUILTIN, OUTPUT);
// Disable all JTAG Pins (usefull for USB BLASTER connection)
pinMode(FPGA_TDO, INPUT);
pinMode(FPGA_TMS, INPUT);
pinMode(FPGA_TDI, INPUT);
pinMode(FPGA_TCK, INPUT);
// Configure other share pins as input too
pinMode(FPGA_INT, INPUT);
// the loop function runs over and over again forever
I'm grateful for any help, cheers!
