Difference between const char array and char array
In a sketch I have defined a function to send a character string to a client from a server in Arduino:
void sendDataToClient( char *sbuf) {
  size_t len = strlen(sbuf) + 1;
  for (i = 0; i < MAXCLIENTS; i++) {
  if (serverClients[i] && serverClients[i].connected()) {
    serverClients[i].write(sbuf, len);
    delay(1);
Initially I have done the test using a constant char array, the function works OK
char bufferMSGtoClient[] = "Hello world!\r\0";
sendDataToClient(bufferMSGtoClient);
Now I want to change the constant for a variable:
char bufferMSGtoClient[30];
time_t t = RTC.get();
formatTime(timestamp, t);
Serial.println( timestamp );
sprintf(bufferMSGtoClient, "%s", timestamp);
And the function no longer works, the client no longer receives the correct data, can someone tell me where I made the mistake?
What data does the client receive? You show some mystery function called formatTime() that presumably populates timestamp, which is a mystery variable and then put that into your buffer. A much easier way of copying strings is to use the strcpy() function. What does that println() function tell you?
Your initial literal string will have 2 nil characters since you explicitly add one into that string.
Check out snippets r us.
It doesn't look like you terminate the string. Maybe
sprintf(bufferMSGtoClient, "%s\r\0", timestamp);
peterkwa, that was missing, thanks!!
wrsalasr:
But using sprintf() will terminate the string so your send function must be broken as it requires 2 nul characters in a string to function properly which is odd.
blh64: But using sprintf() will terminate the string so your send function must be broken as it requires 2 nul characters in a string to function properly which is odd.
Actually it's worse that that, because the resulting string at bufferMSGtoClient will NOT have two nulls with either code.
sprintf expects a null terminated string, and stops copying characters when it reaches the first null. Any \ escapes in character strings are reduced to their ASCII equivalents by the compiler at compile time, NOT by sprintf.
Therefore the suggested solution...
Is no different in operation or output from...
sprintf(bufferMSGtoClient, "%s\r", timestamp);
The only difference is that the first one is passed a doubly null terminated string. sprintf stops at the first null encountered regardless.
So the problem must be elsewhere.
