The example for blinking an LED in the “Getting started with Arduino” book by Massimo Banzi uses:
#define LED 13 //LED connected to digital pin 13
The example that came with the the IDE uses:
int ledPin = 13; // LED connected to digital pin 13
Why did Massimo use #define and the IDE example use int? What I want to do is write a “for statement” that changes the pin assignment i.e.:
for(i=5; i < 11; i++); // applies power to pins 5 through 10
ledPin = i; // increments Pin by plus one (except first time around)
digitalWrite(ledPin, HIGH); // sets ledPin to high
delay(200); // delalys 200 ms
digitalWrite(ledPin, LOW); // sets the ledPin off
Would it matter if I used:
#define ledPin 5
or
int ledPin = 5;
?. I get the I get the feeling I must use int to assign the pin vs. #define, is this correct?
In most introductory sketches, for defining pin numbers, the two approaches are interchangeable.
#define FOO 4 is just a fancy way of setting up a "search and replace" in your code. Wherever "FOO" appears, the compiler pretends it saw a "4" instead. It can't be changed while the sketch is running, and it takes no memory in the processor.
int foo = 4; is a variable. It takes a little memory (two bytes) to store the value, and in fact it takes a little more memory to store the original value you started with. However, this allows the sketch to modify that variable under any desired circumstances, and thus use the new value from that time on.
#define ledPin 5
or
int ledPin = 5;
Answer:
Yes it would matter.
Because the code ledPin = i; tries to assign a value to ledPin, this will not be possible when using either #define or const datatype.
