Difference between two if-processes
Hi community,
i need a little bit of help. What is the difference between a normal if-process like this
if (condition) {
  //statement(s)
and the if-process in that code?
  for (int i=0; i<BlinkButtons; i++)
    BlinkButton[i].Update();
    if (BlinkButton[i].clicks != 0) BlinkLEDfunction[i] = BlinkButton[i].clicks;
    if(BlinkButton[i].clicks == 1) BlinkLedState[i] = !BlinkLedState[i];
    if(BlinkLEDfunction[i] == 2) BlinkLedState[i] = millis() % (650*2) >= 650; //650man 650ms aus
    if(BlinkLEDfunction[i] == 3) BlinkLedState[i] = (millis()/200)%2;
    if(BlinkLEDfunction[i] == -1) BlinkLedState[i] = (millis()/1000)%2;
    if(BlinkLEDfunction[i] == -2) BlinkLedState[i] = (millis()/2000)%2;
    if(BlinkLEDfunction[i] == -3) BlinkLedState[i] = (millis()/3000)%2;
    digitalWrite(BlinkLedPin[i],BlinkLedState[i]);
in this code i'm missing the curly brackets! I understand what the code is doing but i dont understand why its working without the syntax of a normal if-process?!
The special question is: where can i implement the counting process when i only want to blink 3 times?
Thanks a lot for your patience
Z
gnom:
Z
The if/else syntax allows a single statement OR a block of statements. In C/C++ a code block is defined using curly brackets. In general, it is considered good form to always use curly brackets, but not necessary. If you want to execute more than one statement in your if or else block you MUST use curly brackets.
I'm not sure about your second question. If you want to blink 3 times you should use the millis() function to time the blinks. Here are some tutorials to look at:
BlinkWithoutDelay
Arduino Multiple Things
Several Things at a Time
Okay i understand but in my second example i'm missing the curly brackets and that was my question! You didnt answer my question. We i dont have any curly brackets here?
or did i understand you?
Beste
Z
if (BlinkButton[i].clicks == 1) BlinkLedState[i] = !BlinkLedState[i];
Curly brackets are not needed if only one statement is dependant on the test, so all 3 of the above are equivalent
gnom:
I did answer your question: "The if/else syntax allows a single statement OR a block of statements."
This is a single statement:
This is a block of statements:
   i++;
   Serial.println(i);
   Serial.println(BlinkLedState[i]);
BINGO!
@ToddL1962: Sorry i didnt understand your explanation. UKHliBob's is what i understand! It's all equal and when i have only one statement everything is fine without curly brackets.
Thanks a lot! Thats helping! Perfect now the evening is saved and i can sleep well.
The best advice I can give is to always use curly brackets to enclose a code block and for them to be placed alone on a line. If you enter the opening one on a line of its own then the IDE will helpfully add a blank line and the closing one
I have Auto Formatting in the IDE set up to move curly brackets to their own line and, of course to indent the code block that they contain. It is the first thing that I do when I have copied code to the IDE. I do it as a matter of course as I do frequently when entering code of my own
I wouldn't get near a can-o-worms like that if I was you. Just sayin'.. :slight_smile:
-jim lee
jimLee:
-jim lee
It not a can-o-worms if you are right! :slight_smile:
jimLee:
-jim lee
Can you please explain what you mean ?
haha ithink he wanted to be a little bit sarcastic. :wink: so thank you for your advice! sound logical!
Giving out absolutes about coding style. Its like tossing out political slogans.
-jim lee
