Even for simple booleans you can have RMW access, like flag = !flag (assuming flag is volatile, which it probably will be if it has to be protected from an interrupt in the first place).
Sorry - my bad, I meant for simple boolean test and or assignment.
Not a state flip of using the variable state in a RMW like you showed.
I get your point.
Overall, the level of atomicity needed depends on the actual code and how it is written.
--- bill
I don't like to turn off something I don't know isn't already off for some other reason, or on the other side just turning them on I worry that they mightn't have been on score.
It can be done I imagine the long way on whatever platform; the <atomic.c> for AVR appeals to me as it can go to the trouble of saving and restoring state.
That said, I still manage to do without use of interrupts of my own, and trust that those uses as occur in libraries are done correctyl.
Then there's this what I have run into and done
… if you need to write separate bytes of 16 register then you need to write high byte first and then low:
OCR1AH=0x25; OCR1AL=0x64;
This is because 16-bit registers share one particular TEMP register allowing to write 16-bit value at once, but using two clock cycles. If you need to read 16-bit register first has to be low byte and then high.
Always something.
a7
Teensy support a variety of atomic macros:
* This is port of Dean Camera's ATOMIC_BLOCK macros for AVR to ARM Cortex M3
* v1.0
* Mark Pendrith, Nov 27, 2012.
* From Mark:
* >When I ported the macros I emailed Dean to ask what attribution would be
* >appropriate, and here is his response:
* >>Mark,
* >>I think it's great that you've ported the macros; consider them
* >>public domain, to do with whatever you wish. I hope you find them >useful .
* >>Cheers!
* >>- Dean
#ifdef __arm__
#ifndef _CORTEX_M3_ATOMIC_H_
#define _CORTEX_M3_ATOMIC_H_
static __inline__ uint32_t __get_primask(void) \
{ uint32_t primask = 0; \
__asm__ volatile ("MRS %[result], PRIMASK\n\t":[result]"=r"(primask)::); \
return primask; } // returns 0 if interrupts enabled, 1 if disabled
static __inline__ void __set_primask(uint32_t setval) \
{ __asm__ volatile ("MSR PRIMASK, %[value]\n\t""dmb\n\t""dsb\n\t""isb\n\t"::[value]"r"(setval):);
__asm__ volatile ("" ::: "memory");}
static __inline__ uint32_t __iSeiRetVal(void) \
{ __asm__ volatile ("CPSIE i\n\t""dmb\n\t""dsb\n\t""isb\n\t"); \
__asm__ volatile ("" ::: "memory"); return 1; }
static __inline__ uint32_t __iCliRetVal(void) \
{ __asm__ volatile ("CPSID i\n\t""dmb\n\t""dsb\n\t""isb\n\t"); \
static __inline__ void __iSeiParam(const uint32_t *__s) \
__asm__ volatile ("" ::: "memory"); (void)__s; }
static __inline__ void __iCliParam(const uint32_t *__s) \
static __inline__ void __iRestore(const uint32_t *__s) \
{ __set_primask(*__s); __asm__ volatile ("dmb\n\t""dsb\n\t""isb\n\t"); \
__asm__ volatile ("" ::: "memory"); }
#define ATOMIC_BLOCK(type) \
for ( type, __ToDo = __iCliRetVal(); __ToDo ; __ToDo = 0 )
#define ATOMIC_RESTORESTATE \
uint32_t primask_save __attribute__((__cleanup__(__iRestore))) = __get_primask()
#define ATOMIC_FORCEON \
uint32_t primask_save __attribute__((__cleanup__(__iSeiParam))) = 0
#define NONATOMIC_BLOCK(type) \
for ( type, __ToDo = __iSeiRetVal(); __ToDo ; __ToDo = 0 )
#define NONATOMIC_RESTORESTATE \
#define NONATOMIC_FORCEOFF \
uint32_t primask_save __attribute__((__cleanup__(__iCliParam))) = 0
#endif
#endif
