Difference in behavior between Sketch and PlatformIO
I have set up an external interrupt on Pin 18 of the Mega 2560 Rev3 and in the ISR, I set a volatile global variable to the current millis(). This works in an Arduino Sketch as shown below:
const byte LED = 40;
const byte BUTTON = 18;
volatile unsigned long automation_sw = 0;
// Interrupt Service Routine (ISR)
void ISR_automation_switch ()
  if (digitalRead (BUTTON) == HIGH) { // switched OFF
    digitalWrite (LED, LOW);
    automation_sw = 0;
  else { // switched on
    digitalWrite (LED, HIGH);
    automation_sw = millis();
}  // end of switchPressed
void setup ()
  Serial.begin( 9600 );
  pinMode (LED, OUTPUT);  // so we can update the LED
  //digitalWrite (BUTTON, HIGH);  // internal pull-up resistor
  pinMode( BUTTON, INPUT_PULLUP );
  attachInterrupt (digitalPinToInterrupt (BUTTON), ISR_automation_switch, CHANGE);  // attach interrupt handler
}  // end of setup
void loop ()
  // loop doing nothing
  Serial.print(millis() - automation_sw, DEC);
  Serial.print("\t");
  Serial.println(automation_sw, DEC);
However, when I run the exact same code as part of a bigger program in PlatformIO, the value of automation_sw stays at 0 all the time.
I initially suspected debouncing of the switch, hence I cross-checked by correcting for it. However, in the second case, the value of automation_sw is always 0. This is quite perplexing and I'd like to know if I'm missing something here.
Thanks,
B
You haven't posted the code that has the problem.
The problematic code is exactly the same. I added prints in both cases of the ISR to check the behavior. Whenever the switch is toggled, the ISR is fired correctly and a call counter is incremented as below:
void ISR_automation_switch()
   if (digitalRead(AUTO_SWITCH_PIN) == HIGH) { // Automation switched OFF
     auto_sw_timeout = 0;
     automation_state = OFF;
     digitalWrite(AUTO_STATUS_PIN, LOW);
     count1++;
     Serial.print("OFF");
     Serial.print(" ");
     Serial.println(count1, DEC);
   else { // Automation switched on
     auto_sw_timeout = millis();
     automation_state = ON;
     digitalWrite (AUTO_STATUS_PIN, HIGH);
     count2++;
     Serial.print("ON");
     Serial.print(" ");
     Serial.println(count2, DEC);
However the value of auto_sw_timeout does not get updated and stays 0. I am unable to explain this behavior..
