Hi, sadly I can't show the serial prints I'm getting to explain my problem visually, because I won't have access to my Arduino until Monday, but I'll do my best with words:
For a university project, I wrote a code that keeps track of the time (using millis() function), and once the difference between the reference time (the time at which the program starts its cycle) and the current time exceeds a certain threshold (we use a range from 1.5 to 5 seconds), it deactivates the program, until we trigger it again. This allows us to measure over a closed interval of time, without a new result appearing on the screen over and over again.
However, at some (random?) point, this part of the code
starts to spit out the measured frequencies with almost no interval between. To test what caused this, I added that Serial.print part and it appears that at some point the difference
millis()-reference
becomes very large (jumps to a value around hundreds of thousands), and therefore is constantly larger than the off_time (which is around 1500-5000). Sidenote: reference too is defined as an integer, so I doubt the problem is in the definition of the values.
that's true, it doesn't, because the activate() function does that instead, which runs before the counter loop can be started;
and i mean, it works fine for the first ~20 seconds or so, but breaks down later
thanks for the suggestion though!
It depends on the hardware platform. That is why using int may result in a different size integer for different processors. This is one reason the following typedefs are provided so that the definitions are unambiguous:
