differences between uploading sketches toanother boards
Hi, Guys!
I use 3 different boards: NANO, WavGat UNO and WavGat MEGA 2560. In previous days I uploaded different sketches to UNO and to MEGA, and today I planned to test my BAROs - BMP180, BMP280.
I tried to upload the Basic BMP180 sketch, but the upload was not ready, the Ard IDE gave me error codes:
https://www.google.com/search?client=firefox-b-d&q=avrdude%3A+stk500_recv()%3A+programmer+is+not+responding
I couldn’t solved the problem, although I tested all possibilities in above homepages…
What do You think, what is the problem? May I dowload -install board driver of NANO? Or what?
Thanks: rcph
BMP180 teszt.txt (78 Bytes)
driver update didn't solved this problem
rcpilot_hun:
Were the uploads successful?
rcpilot_hun:
Which board did you upload to?
rcpilot_hun:
arduino uno - How do I resolve "avrdude: stk500_recv(): programmer is not responding"? - Arduino Stack Exchange
ftdi - avrdude: stk500_recv(): programmer is not responding - Arduino Stack Exchange
avrdude: stk500_recv(): programmer is not responding - Google Search
I’m glad to see you did some research on the issue, but we do need you to post the full error output here.
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to “Show verbose output during: compilation”
  • Check the checkbox next to "Show verbose output during: upload
  • Click “OK”
  • Sketch > Upload
  • After the upload fails, you’ll see a button on the right side of the orange bar “Copy error messages” (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
rcpilot_hun:
BMP180 teszt.txt
That file only contains the URL: BMP180 Barometric Pressure Sensor Hookup - learn.sparkfun.com. It’s pretty silly to make us download a file for something you could have posted directly to the forum.
Hello, Pert!
Thank You very much the fast reply. Meantime I uploaded this sketch to my MEGA 2560, and this program is working:
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\fgabor\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\fgabor\AppData\Local\Temp\arduino_build_978547/BMP180_teszt.ino.hex"
avrdude: writing flash (8814 bytes):
Writing | ################################################## | 100% 1.36s
avrdude: 8814 bytes of flash written
avrdude: verifying flash memory against C:\Users\fgabor\AppData\Local\Temp\arduino_build_978547/BMP180_teszt.ino.hex:
avrdude: load data flash data from input file C:\Users\fgabor\AppData\Local\Temp\arduino_build_978547/BMP180_teszt.ino.hex:
avrdude: input file C:\Users\fgabor\AppData\Local\Temp\arduino_build_978547/BMP180_teszt.ino.hex contains 8814 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.06s
avrdude: verifying ...
avrdude: 8814 bytes of flash verified
avrdude done. Thank you.
Good news! Well, if you have any more problems uploading, feel free to come back with more information and we'll try to help out.
Uncheck the checkbox next to "Show verbose output during: compilation"
I made these. Pls wait, I try to upload again the sketch to the NANO...
Using Port : COM4
Using Programmer : arduino
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x64
Probléma az alaplapra feltöltéskor.
Try selecting Tools > Processor > ATmega328P (Old Bootloader) and then upload again.
THAAAAAAAAAAAAAAAAAAAAAAAAANKS !!! :):):slight_smile:
System wide configuration file is “C:\Users\fgabor\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf”
Using Port : COM4
Overriding Baud Rate : 57600
AVR Part : ATmega328P
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file “C:\Users\fgabor\AppData\Local\Temp\arduino_build_406746/BMP180_teszt.ino.hex”
avrdude: writing flash (8508 bytes):
Writing | ################################################## | 100% 2.47s
avrdude: 8508 bytes of flash written
avrdude: verifying flash memory against C:\Users\fgabor\AppData\Local\Temp\arduino_build_406746/BMP180_teszt.ino.hex:
avrdude: load data flash data from input file C:\Users\fgabor\AppData\Local\Temp\arduino_build_406746/BMP180_teszt.ino.hex:
avrdude: input file C:\Users\fgabor\AppData\Local\Temp\arduino_build_406746/BMP180_teszt.ino.hex contains 8508 bytes
Reading | ################################################## | 100% 1.86s
avrdude: verifying …
avrdude: 8508 bytes of flash verified
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
