different array values returned from function
Hello,
sorry if there is error in my language.
I want to know what is the problem with my code
const int LDR1 = A0;
const int LDR2 = A2;
const char SEPARATOR[] = ", \t";
void plotSignal(int n, int s[]) {
  int i;
  for (i = 0; i < n - 1; i++) {
    Serial.print(s[i]);
    Serial.print(SEPARATOR);
  Serial.println(s[i]);
void ldrInit() {
  pinMode(LDR1, INPUT);
  pinMode(LDR2, INPUT);
int *ldrRead() {
  int data[3];
  data[0] = analogRead(LDR1);
  data[1] = analogRead(LDR2);
  data[2] = millis() / 1000;
  plotSignal(3, data);
  return data;
unsigned long last_millis = 0;
  ldrInit();
  if (millis() - last_millis > 1000) {
    int *data = ldrRead();
    data[3] = 180;
    last_millis = millis();
So i want to read data from LDR sensor and print it in serial monitor. The problem is the value from void loop is different from what is initially read from inside the function. I am expecting the two data has the same value at least for the first two element in the array.
The schematics is in Schematics.jpg if you need it
thanks in advance
p.s. I am using Arduino Nano with old bootloader
Don't return a pointer to a stack object.
You could make the
  int data[3];
  static int data[3];
The
  int data[3];
in the function causes the compiler to put the values on the stack
When you return from the function, values previously held on the stack are pulled off so that the state of the program is restored to how it was when the function was called and hence the value of locally declared variables are lost
Of you declare the data array as static, as suggested, it will prevent the value being put on the stack and being lost. You could achieve the same thing by declaring the data array as global and thus removing the need to return it
I also see
    data[3] = 180;
in the program. Does the data array actually have an element numbered 3 ?
Works like a charm
Thanks for the answer. I am struggling with pointers, memory, and things like that in C.
btw the
data[2] =180
doesn't have any meaning it just to differentiate the two outputs
i think it was some residue from the bigger code to control a servo motor
data[2] =180
would not be a problem as long as that is what you meant to do
However
data[3] =180
could be if the data array only has 3 elements
