This is my standard 6 axes 28 inputs setup, no encoders.
I'm getting the ''Input ID 1'' 4 times. Once in every serie. (A,B,C,D)
@Delta_G don't be so critical, this is @vandoos 's first post.
@vandoos : check this out. It details how to get the best out of this forum: How to get the best out of this forum
Thanks!
#include <Keypad.h>
#include <Keyboard.h>
#include <Keypad.h>
#include <Joystick.h>
//DEFINITIONS
#define ENABLE_PULLUPS
#define NUMROTARIES 0 //replace "?" with number of rotary encoders you are using
#define NUMBUTTONS 28//replace "?"with number of buttong you are using
#define NUMROWS 7 //replace "?" with number of rows you have
#define NUMCOLS 4 //replace "?" with number of columns you have
//BUTTON MATRIX
//first change number of rows and columns to match your button matrix,
//then replace all "?" with numbers (starting from 0)
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3},
{4,5,6,7},
{8,9,10,11},
{12,13,14,15},
{16,17,18,19},
{20,21,22,23},
(24,25,26,27)
//struct rotariesdef {
// byte pin1;
// byte pin2;
// int ccwchar;
// int cwchar;
// volatile unsigned char state;
////ROTARY ENCODERS
////each line controls a different rotary encoder
////the first two numbers refer to the pins the encoder is connected to
////the second two are the buttons each click of the encoder wil press
////do NOT exceed 31 for the final button number
//rotariesdef rotaries[NUMROTARIES] {
// {0,1,22,23,0}, //rotary 1
//{2,3,24,25,0}, //rotary 2
//{4,5,26,27,0}, //rotary 3
//{6,7,28,29,0} //rotary 4
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
//BUTTON MATRIX PART 2
byte rowPins[NUMROWS] = {7,8,9,10,11,12,13}; //change "?" to the pins the rows of your button matrix are connected to
byte colPins[NUMCOLS] = {0,1,2,3}; //change "?" to the pins the rows of your button matrix are connected to
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//JOYSTICK SETTINGS
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK,
28, //number of buttons
0, //number of hat switches
//Set as many axis to "true" as you have potentiometers for
true, // y axis
true, // x axis
true, // z axis
true, // rx axis
true, // ry axis
true, // rz axis
false, // rudder
false, // throttle
false, // accelerator
false, // brake
false); // steering wheel
const int numReadings = 20;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int currentOutputLevel = 0;
//POTENTIOMETERS PART 1
//add all the axis' which are enabled above
int yAxis_ = 0;
int xAxis_ = 0;
int zAxis_ = 0;
int RxAxis_ = 0;
int RyAxis_ = 0;
int RzAxis_ = 0;
//POTENTIOMETERS PART 2
//Which pins are your potentiometers connected to?
int potentiometerPin1 = A0; //Change "?" to the pin your potentiometer is connected to
int potentiometerPin2 = A1;
int potentiometerPin3 = A2;
int potentiometerPin4 = A3;
int potentiometerPin5 = A4;
int potentiometerPin6 = A5;
const bool initAutoSendState = true;
Joystick.begin();
rotary_init();
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
CheckAllEncoders();
CheckAllButtons();
CheckAllPotentiometers();
//POTENTIOMETERS PART 3
//change the details to match teh details above for each potentiometer you are using
void CheckAllPotentiometers(){
//potentiometer 1
currentOutputLevel = getAverageOutput(potentiometerPin1);
yAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setYAxis(yAxis_);
//potentiometer 2
currentOutputLevel = getAverageOutput(potentiometerPin2);
xAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setXAxis(xAxis_);
//potentiometer 3
currentOutputLevel = getAverageOutput(potentiometerPin3);
zAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setZAxis(zAxis_);
//potentiometer 4
currentOutputLevel = getAverageOutput(potentiometerPin4);
RxAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setRxAxis(RxAxis_);
//potentiometer 5
currentOutputLevel = getAverageOutput(potentiometerPin5);
RyAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setRyAxis(RyAxis_);
//potentiometer 6
currentOutputLevel = getAverageOutput(potentiometerPin6);
RzAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setRzAxis(RzAxis_);
int getAverageOutput(int pinToRead){
index = 0;
total = 0;
while (index < numReadings){
readings[index] = analogRead(pinToRead);
total = total + readings[index];
index = index + 1;
//delay (1);
return total / numReadings;
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key[i].stateChanged )
switch (buttbx.key[i].kstate) {
case PRESSED:
case HOLD:
Joystick.setButton(buttbx.key[i].kchar, 1);
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
for (int i=0;i<NUMROTARIES;i++) {
// pinMode(rotaries[i].pin1, INPUT);
// pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
// digitalWrite(rotaries[i].pin1, HIGH);
// digitalWrite(rotaries[i].pin2, HIGH);
#endif
unsigned char rotary_process(int _i) {
//Serial.print("Processing rotary: ");
//Serial.println(_i);
// unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
// rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
// return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
Serial.println("Checking rotaries");
unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Serial.print("Rotary ");
Serial.print(i);
Serial.println(" <<< Going CCW");
// Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
if (result == DIR_CW) {
Serial.print(i);
Serial.println(" >>> Going CW");
// Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
Serial.println("Done checking");
This is a code template from someone else that I modify for my needs, I personnally do not right code.
THX for the help
Using Leonardo board
