I’m using 10k pot to send MIDI data. The issue that I’m having is that when I try to map that pot in my DJ software (Traktor Pro), it reads different values like:
Ch02.CC.032
Ch02.CC.021
Ch02.CC.000
Why is that? I’ve tried using 2 codes, first one I found on instructables (with some edits) and 2nd is mine. Same issues are appearing, with code 2 giving even more values:
Code 1:
//#define DEBUG
#define FILTER_AMOUNT 7
// Timeout is in microseconds
#define ANALOGUE_INPUT_CHANGE_TIMEOUT 250000
// Contains the current value of the analogue inputs.
int analogueInputs[6];
// Variable to hold temporary analogue values, used for analogue filtering logic.
int tempAnalogueInput;
// for loop
int i = 0;
// Variable to hold difference between current and new analogue input values.
int analogueDiff = 0;
// This is used as a flag to indicate that an analogue input is changing.
boolean analogueInputChanging[6];
// Time the analogue input was last moved
unsigned long analogueInputTimer[6];
Serial.begin(31250);
// Initialise each analogue input channel.
for (i = 0; i < 1; i++)
// Set the pin direction to input.
pinMode(i, INPUT);
// Initialise the analogue value with a read to the input pin.
analogueInputs[i] = analogRead(i);
#ifdef DEBUG
Serial.print("read in setup: ");
Serial.println(analogueInputs[i]);
#endif
// Assume no analogue inputs are active
analogueInputChanging[i] = false;
analogueInputTimer[i] = 0;
* Analogue input logic:
* The Arduino uses a 10-bit (0-1023) analogue to digital converter (ADC) on each of its analogue inputs.
* The ADC isn't very high resolution, so if a pot is in a position such that the output voltage is 'between'
* what it can detect (say 2.505V or about 512.5 on a scale of 0-1023) then the value read will constantly
* fluctuate between two integers (in this case 512 and 513).
* If we're simply looking for a change in the analogue input value like in the digital case above, then
* there will be cases where the value is always changing, even though the physical input isn't being moved.
* This will in turn send out a constant stream of MIDI messages to the connected software which may be problematic.
* To combat this, we require that the analogue input value must change by a certain threshold amount before
* we register that it is actually changing. This is good in avoiding a constantly fluctuating value, but has
* the negative effect of a reduced input resolution. For example if the threshold amount was 2 and we slowly moved
* a slider through it's full range, we would only detect every second value as a change, in effect reducing the
* already small 7-bit MIDI value to a 6-bit MIDI value.
* To get around this problem but still use the threshold logic, a timer is used. Initially the analogue input
* must exceed the threshold to be detected as an input. Once this occurs, we then read every value coming from the
* analogue input (not just those exceeding a threshold) giving us full 7-bit resolution. At the same time the
* timer is started. This timer is used to keep track of whether an input hasn't been moved for a certain time
* period. If it has been moved, the timer is restarted. If no movement occurs the timer is just left to run. When
* the timer expires the analogue input is assumed to be no longer moving. Subsequent movements must exceed the
* threshold amount.
// Read the analogue input pin, dividing it by 8 so the 10-bit ADC value (0-1023) is converted to a 7-bit MIDI value (0-127).
tempAnalogueInput = analogRead(i);
#ifdef DEBUG
Serial.print("read in loop: ");
Serial.println(tempAnalogueInput);
#endif
// Take the absolute value of the difference between the curent and new values
analogueDiff = abs(tempAnalogueInput - analogueInputs[i]);
#ifdef DEBUG
Serial.print("difference: ");
Serial.println(analogueDiff);
Serial.print("\n");
delay(2000);
#endif
// Only continue if the threshold was exceeded, or the input was already changing
if ((analogueDiff > 0 && analogueInputChanging[i] == true) || analogueDiff >= FILTER_AMOUNT)
// Only restart the timer if we're sure the input isn't 'between' a value
// ie. It's moved more than FILTER_AMOUNT
if (analogueInputChanging[i] == false || analogueDiff >= FILTER_AMOUNT)
// Reset the last time the input was moved
analogueInputTimer[i] = micros();
// The analogue input is moving
analogueInputChanging[i] = true;
else if (micros() - analogueInputTimer[i] > ANALOGUE_INPUT_CHANGE_TIMEOUT)
// Only send data if we know the analogue input is moving
if (analogueInputChanging[i] == true)
// Record the new analogue value
analogueInputs[i] = tempAnalogueInput;
#ifdef DEBUG
Serial.print("Value to send: ");
Serial.println(analogueInputs[i]/8);
#endif
// Send the analogue value out on the general MIDI CC (see definitions at beginning of this file)
controlChange(177, 21+i, analogueInputs[i]/8);
// Send a MIDI control change message
void controlChange(int channel, int control, int value)
Serial.print(channel, BYTE);
Serial.print(control, BYTE);
Serial.print(value, BYTE);
Code 2:
//current reading from pot
int sendval[2] = {0, 0};
//previous reading from pot
int last[2] = {0, 0};
//difference between current and previous reading
int diff[2] = {0, 0};
//for loop variable
int i = 0;
for (i=0; i<1; i++) {
sendval[i]=analogRead(i);
diff[i]=abs(sendval[i]-last[i]);
if ( (sendval[i]/8 != last[i]/8 ) && (diff[i]>7) )
//Serial.println(sendval[i]/8, DEC);
midiCC(177, 21, sendval[i]/8);
// update last variable
last[i] = sendval[i];
// this function sends a Midi CC.
void midiCC(char CC_data, char c_num, char c_val){
Serial.print(CC_data, BYTE);
Serial.print(c_num, BYTE);
Serial.print(c_val, BYTE);
Oh and for the record, I’m using this scheme also: shiftmore: Quick and Dirty Arduino Midi Over USB
Any help is appreciated.
